Fortigate 200F firewall - IPS Signature checking issue
CMK version: 2.1.0p10
OS version: CentOS 7.9.2009
I’m monitoring a Fortigate Firewall 200F - v6.4.9 build1966 (GA)
I receive the following alert from the Signatures check plugin:
[90.05327] AV age: 10 h
[6.00741] IPS age: 6.7 y (warn/crit at 24 h/2 d)CRIT
[90.05327] AV extended age: 10 h
[22.00377] IPS extended age: 5.5 d
The problem is that IPS signature are actually updated whereas the plugin reports a critical condition for IPS (6.7 y old…)
I think that the plugin is checking the OID:
1.3.6.1.4.1.12356.101.4.2.2.0
which reports (in my case): STRING: “6.00741(2015-12-01 02:30)”
I think that the correct OID shoulld be:
.1.3.6.1.4.1.12356.101.4.2.4.0
which reports (in my case): STRING: “22.00377(2022-08-18 00:04)”
Checkmk version 2.1.0p10
Trying to acquire lock on /omd/sites/Equita/var/check_mk/license_usage/next_run
Got lock on /omd/sites/Equita/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/Equita/var/check_mk/license_usage/history.json
Got lock on /omd/sites/Equita/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/Equita/var/check_mk/license_usage/history.json
Released lock on /omd/sites/Equita/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/Equita/var/check_mk/license_usage/next_run
Released lock on /omd/sites/Equita/var/check_mk/license_usage/next_run
Updating IPv4 DNS cache for wscapture: 170.1.7.168
Trying to acquire lock on /omd/sites/Equita/var/check_mk/ipaddresses.cache
Got lock on /omd/sites/Equita/var/check_mk/ipaddresses.cache
Releasing lock on /omd/sites/Equita/var/check_mk/ipaddresses.cache
Released lock on /omd/sites/Equita/var/check_mk/ipaddresses.cache
  • FETCHING DATA
    [cpu_tracking] Start [7f45d44c7340]
    [PiggybackFetcher] Fetch with cache settings: NoCache(wscapture, base_path=/omd/sites/Equita/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
    No piggyback files for ‘wscapture’. Skip processing.
    No piggyback files for ‘170.1.7.168’. Skip processing.
    [cpu_tracking] Stop [7f45d44c7340 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
  • PARSE FETCHER RESULTS
    No persisted sections
    → Add sections: []
    Received no piggyback data
    [cpu_tracking] Start [7f45d44c7d30]
    value store: synchronizing
    Trying to acquire lock on /omd/sites/Equita/tmp/check_mk/counters/wscapture
    Got lock on /omd/sites/Equita/tmp/check_mk/counters/wscapture
    Releasing lock on /omd/sites/Equita/tmp/check_mk/counters/wscapture
    Released lock on /omd/sites/Equita/tmp/check_mk/counters/wscapture
    [cpu_tracking] Stop [7f45d44c7d30 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
    execution time 0.0 sec | execution_time=0.000 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
We had a case open with Fortinet to clear this up.
They wrote:
Indeed, if you are not using the Extended DB, then you will get the old value.
But if you do not use it, you also would not need to query it at all.
So the workaround would be to just keep the OID out of the query.
In conclusion, we’ve simply used the rule parameters to disregard the “normal” IPS value entirely. As I don’t know which FortiOS firmware version made the behavior change I don’t think the plugin itself can be updated to handle this edge case by itself, so I suggest you create a similar rule to prevent false positive alarms.
grafik
