This sounds like a configuration problem on the FortiGate, not a generic problem from checkmk.
Have you tested querying the FortiGate with others tools over SNMP such as snmpwalk from a Linux machine or the MIB Browser (Free MIB Browser / MIB Browser / SNMP Browser.) from Windows PC?
On the Forti, you have to:
enable SNMP on the interfaces (IPv4 and IPv6 indenpendently)
enable the SNMP agent
create a community name (as you did)
add a host with the IP address from the checkmk server within that community with the Query enabled
config system snmp community
edit 1
set name "YourCommunityString"
config hosts
edit 1
set ip 192.168.5.20 255.255.255.255
next
end
set query-v1-status disable
set trap-v1-status disable
set trap-v2c-status disable
next
end
thank you for the last response it solved my problem.
But now I would like to monitor our Fortimail but I get the default snmp error:
Starting job… SNMP scan failed: Cannot fetch system description OID .1.3.6.1.2.1.1.1.0. Please check your SNMP configuration. Possible reason might be: Wrong credentials, wrong SNMP version, Firewall rules, etc. Completed.
This is my snmp configuration I can’t understand why here it isn’t working…
Ping from the monitoring server to the fortimail is working (it’s the same configuration like on the fortigate where it works without problems)
Hey @Matthew1,
I’m sorry, but I have no experience with the FortiMail. The configuration snippet looks quite good to me. Just to be sure: the IPv4 address you garbled in the screenshot above is the one from the checkmk server, right?
Otherwise, the error output is a best practice:
@Matthew1 Where have you found this ‘Advanced Setting’ - we’Re facing the same issues with fortigate firewalls - we have one that is working fine with SNMP in CheckMK and three others the don’t. TI’m not the network device specialist, - but the one for CHeckMK and want to help the Network guys.
If you could lead me to the setting that helped you, that would be very nice.
