We are considering an appliance that has Ganglia built in. Is there a way to get Ganglia’s output and use it as input for CheckMK?
Thanks
Thanks
Hi Timotheus,
there is no official integration for Ganglia to Checkmk. Also, I could not find anything in the Exchange or the usual sources. To answer your question: If you don’t want to write your own integration, unfortunately I do not see a way to do that. I would suggest to try adding your hosts directly to Checkmk.
Regards
Sven
