Setup a manual check for this process where the parameters for number of processes are set to 0. This should create a service check that is OK if the process is not running.
With a matching time period you can set a notification period that is only active during daytime.
Hi, Thx i think this worked and i know now where to look.
I have done a process discovery and used the ruleset for process count. This seems to work the same way.
Your suggestion using a manual check was because this is done without discovery and therefore do not need a running process to implement the service ? ( it has the regex in the check parameters )
If using a time period service monitoring i will still need a notification period as well ? I βthoughtβ the Monitoring of the process monitoring service during Backup hours will be disabled. So i should not get a notification during that time of that as well ?
Notification should be sent out 7x24 ( only such an example should not produce any in given time period)
