I have a lot of hosts running nicely in Check MK and now I want to open it up so that our operations guys can see it.
I have some contact groups setup and I have assigned the contact group permissions on the folders of hosts that I want them to be able to see and that works just fine.
But I really want to make it so that they cannot, for example, see any error/warnings from windows log files. There are some other checks that I would also like to exclude from their view.
Back to the initial topic: Your question is very broad and very generic.
Maybe someone finds the time to answer extensively, but do not hold your breath.
There are a lot of ways how to configure permissions in Checkmk and what you want to do is certainly possible, but there are several ways how to achieve it.
What you are looking for can certainly be achieved my combining ‘roles’, ‘users’ and ‘contact groups’
Checkmk has three built-in roles - Admin, User, and Guest.
Broadly speaking, as the names suggest, the Admin can do everything, User can do many things, except administering the monitoring sites, and the Guest can basically only “look, but don’t touch”
(EDIT: 4 roles, the ‘agent_registration’ user was added with 2.2. Not relevant for this, though))
Now the most efficient way to do what you want to achieve is to clone the role that most closely resembles the desired “operations-team” role (probably user), and modify it’s permissions. You can do this VERY granularly, there are more than 400 individual permissions that can be set (that’s also why you don’t want to start from scratch, if you can avoid it).
Then you can assign that role to individual users. These users in turn are part of contact groups for the different hosts.
If it comes to individual services, you probably need to assign those services to a different contact group. (not sure if you can negate that, though…)
Even if this might be a lot of work we do have all services disabled by default and we then assign different services to different contact groups, and do not automatically assign services to contacts.
This is really powerful as we can have team A who is responsible for the OS see all OS related services, then Team B has an application, lets say a database, and they will see all the database checks (but not the OS) and Team A won’t see Team Bs services.
The only major downside is that any view that contains “hosts” won’t be seen by Team B, so the host up/down will not work for Team B - a workaround is to have a separate Ping/ICMP service and assign that to Team B.
