CMK version: 2.1.0p18 CRE
OS version: Debian 11
Output of cmk -nv --detect-plugins=local hostname
OMD[bk]:~$ cmk -nv --detect-plugins=local wmsserver
* FETCHING DATA
No piggyback files for 'wmsserver'. Skip processing.
No piggyback files for '192.168.200.90'. Skip processing.
Plenty_Info: Status 11.02 [6583,6594] This is a local Check, Count: 2.00
Plenty_Info: Status 11.03 [], Count: 0.00
[agent] Success, execution time 93.0 sec | execution_time=93.020 user_time=0.010 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=93.000
Output of cmk --debug -vvn hostname
MD[bk]:~$ cmk --debug -vvn wmsserver
Checkmk version 2.1.0p18
Trying to acquire lock on /omd/sites/bk/var/check_mk/license_usage/next_run
Got lock on /omd/sites/bk/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/bk/var/check_mk/license_usage/history.json
Got lock on /omd/sites/bk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/bk/var/check_mk/license_usage/history.json
Released lock on /omd/sites/bk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/bk/var/check_mk/license_usage/next_run
Released lock on /omd/sites/bk/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f96da8d4520]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(wmsserver, base_path=/omd/sites/bk/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
Connecting via TCP to 192.168.200.90:6556 (5.0s timeout)
Reading data from agent
Write data to cache file /omd/sites/bk/tmp/check_mk/cache/wmsserver
Trying to acquire lock on /omd/sites/bk/tmp/check_mk/cache/wmsserver
Got lock on /omd/sites/bk/tmp/check_mk/cache/wmsserver
Releasing lock on /omd/sites/bk/tmp/check_mk/cache/wmsserver
Released lock on /omd/sites/bk/tmp/check_mk/cache/wmsserver
Closing TCP connection to 192.168.200.90:6556
[cpu_tracking] Stop [7f96da8d4520 - Snapshot(process=posix.times_result(user=0.0, system=0.009999999999999981, children_user=0.0, children_system=0.0, elapsed=87.09999999776483))]
[cpu_tracking] Start [7f96da8cd4c0]
[PiggybackFetcher] Fetch with cache settings: NoCache(wmsserver, base_path=/omd/sites/bk/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
[cpu_tracking] Stop [7f96da8cd4c0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<df>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_instances>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_sessions>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_stat_database:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_locks:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_query_duration:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_connections:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_stats:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_version:sep(1)>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_conn_time>>> / Transition HostSectionParser -> HostSectionParser
<<<postgres_bloat:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
-> Add sections: ['check_mk', 'cifsmounts', 'cpu', 'df', 'diskstat', 'job', 'kernel', 'labels', 'lnx_if', 'local', 'md', 'mem', 'mounts', 'nfsmounts', 'postgres_bloat', 'postgres_conn_time', 'postgres_connections', 'postgres_instances', 'postgres_locks', 'postgres_query_duration', 'postgres_sessions', 'postgres_stat_database', 'postgres_stats', 'postgres_version', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'uptime', 'vbox_guest']
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f96da969790]
value store: synchronizing
Trying to acquire lock on /omd/sites/bk/tmp/check_mk/counters/wmsserver
Got lock on /omd/sites/bk/tmp/check_mk/counters/wmsserver
Releasing lock on /omd/sites/bk/tmp/check_mk/counters/wmsserver
Released lock on /omd/sites/bk/tmp/check_mk/counters/wmsserver
CPU load 15 min load: 2.52, 15 min load per core: 0.63 (4 cores)
CPU utilization Total CPU: 47.38%
Check_MK Agent Version: 2.0.0p19, OS: linux
Disk IO SUMMARY PEND - Initializing counters
Filesystem / 51.47% used (25.27 of 49.10 GB), trend: 0.00 B / 24 hours
Interface 2 [ens33], (up), MAC: 00:0C:29:28:2F:0A, Speed: 1 GBit/s
Interface 3 [br-59ed40c04ade], (up), MAC: 02:42:3E:A3:A5:96, Speed: unknown
Kernel Performance Process Creations: 0.00/s, Context Switches: 0.00/s, Major Page Faults: 0.00/s, Page Swap in: 0.00/s, Page Swap Out: 0.00/s
Memory Total virtual memory: 24.55% - 1.41 GB of 5.75 GB, 9 additional details available
Mount options of / Mount options exactly as expected
Number of threads 295, Usage: 0.96%
PostgreSQL ANALYZE MAIN/postgres No never checked tables
PostgreSQL ANALYZE MAIN/sscwmsdb Table: td_stocktaking_record_20220108, Not analyzed for: 1 year 137 days, No never checked tables
PostgreSQL Bloat MAIN/postgres Maximum table bloat at pg_amproc: 0.25%, Maximum wasted tablespace at pg_collation: 16.00 kB, Maximum index bloat at pg_amproc: 0.5%, Maximum wasted indexspace at pg_depend: 96.00 kB, Summary of top 10 wasted tablespace: 120.00 kB, Summary of top 10 wasted indexspace: 128.00 kB
PostgreSQL Bloat MAIN/sscwmsdb Maximum table bloat at plenty_stock: 0.83%, Maximum wasted tablespace at log_action: 90.02 MB, Maximum index bloat at plenty_stock_movement: 0.76%, Maximum wasted indexspace at plenty_stock_movement: 21.41 MB, Summary of top 10 wasted tablespace: 267.29 MB, Summary of top 10 wasted indexspace: 32.85 MB
PostgreSQL Connection Time MAIN 0.083 seconds
PostgreSQL Connections MAIN/postgres Used active connections: 1, Used active percentage: 0.5%, Used idle connections: 0, Used idle percentage: 0%
PostgreSQL Connections MAIN/sscwmsdb Used active connections: 0, Used active percentage: 0%, Used idle connections: 7, Used idle percentage: 3.5%
PostgreSQL DB MAIN/postgres Size Size is 7.44 MB
PostgreSQL DB MAIN/postgres Statistics Blocks Read: 0.00/s, Fetches: 0.00/s, Commits: 0.00/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/sscwmsdb Size Size is 2.79 GB
PostgreSQL DB MAIN/sscwmsdb Statistics Blocks Read: 0.00/s, Fetches: 0.00/s, Commits: 0.00/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/template0 Size Size is 7.44 MB
PostgreSQL DB MAIN/template0 Statistics Blocks Read: 0.00/s, Fetches: 0.00/s, Commits: 0.00/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL DB MAIN/template1 Size Size is 7.44 MB
PostgreSQL DB MAIN/template1 Statistics Blocks Read: 0.00/s, Fetches: 0.00/s, Commits: 0.00/s, Deletes: 0.00/s, Updates: 0.00/s, Inserts: 0.00/s
PostgreSQL Daemon Sessions MAIN Total: 2, Running: 2
PostgreSQL Instance MAIN Status: running with PID 1341
PostgreSQL Locks MAIN/postgres Access Share Locks 1, Exclusive Locks 0
PostgreSQL Locks MAIN/sscwmsdb Access Share Locks 6, Exclusive Locks 0
PostgreSQL Query Duration MAIN/postgres Longest query: 0 seconds, PID: 121035, Query: SELECT datname, datid, usename, client_addr, state AS state, COALESCE(ROUND(EXTRACT(epoch FROM now()-query_start)),0) AS seconds, pid, regexp_replace(query, E'[\n\r\u2028]+', ' ', 'g' ) AS current_query FROM pg_stat_activity WHERE (query_start IS NOT NULL AND (state NOT LIKE 'idle%' OR state IS NULL)) ORDER BY query_start, pid DESC
PostgreSQL Query Duration MAIN/sscwmsdb No queries running
PostgreSQL VACUUM MAIN/postgres No never checked tables
PostgreSQL VACUUM MAIN/sscwmsdb Table: td_stocktaking_record_20220108, Not vacuumed for: 1 year 137 days, No never checked tables
PostgreSQL Version main PostgreSQL 10.23 (Ubuntu 10.23-0ubuntu0.18.04.2) on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0, 64-bit
Systemd Service Summary Total: 141, Disabled: 5, Failed: 2, 2 services failed (networkd-dispatcher, unattended-upgrades)(!!)
TCP Connections Established: 27
Uptime Up since Sep 07 2023 16:34:50, Uptime: 4 days 23 hours
[cpu_tracking] Stop [7f96da969790 - Snapshot(process=posix.times_result(user=0.03000000000000025, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.03999999910593033))]
[agent] Success, execution time 87.1 sec | execution_time=87.140 user_time=0.030 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=87.090
I’d assume, checks are running the way, they should. As they ever did.
I did scheduled OS update (apt get update / upgrade) and I think it was about this time, monitoring of this host stopped working. I was investigating in this update, but since checks are running perfectly fine, there must be a different problem.
In the servers GUI all hosts look fine but this one:
I got stuck - any hint what to look for are appreciated.
