ubuntu 20.04
Checkmk 2.0.0p4
We leverage HAProxy in our environment a bit different than what Check_MK is expecting.
Meaning, there will always be 1 or more backend servers in a DOWN state and only 1 UP. Currently Check_mk sees these DOWN states as a critical which isn’t really a problem as long as there’s still one UP.
If possible, we’d like to have Check_mk treat all HAProxy UP or DOWN and report accordingly. Could you please share your thoughts in achieving the same
I have implemented BI and enabled notification also. But the existing service also showing alert/notification , disabling those service also disables the BI aggregation too. What to do to ignore those related services?
Did this and the notification mails were stopped , but still it is showing in “Service Problems (unhandled)” section of the dashboard , is there a way to hide/remove from that section?
I have put the services to Service Group.
Tried to point Service Group tp other Contact group , but couldn’t figure it out.
Could you please share the detailed steps for for pointing the SG to Contact Group??
First of all I have to apologize, I made a mistake in thinking … Unfortunately, service groups only work in the notifications. I had implemented the hiding of the services via the service labels, which can then be assigned to the contact groups.
