Help to find Notification Method/Contact Selection option in CMK 2.0
Hai CMK Community,
Any one help me to get the Notification Method/Contact Selection option in CMK 2.0. I am try to refer the CMK documentation but its out dated/not updated with new version of CMK or am missing some thing. Please help me to get the option because mail alert option stuck with 2 mail id’s. can any one share with img also for better understanding to rectify my issue.
Hi Rojy,
not sure if I understand you correctly, but if you are looking for where to set up notificatoins rules, these screenshots should help. In general, searching in the “Setup” menu often will find what you’re looking for.
grafik
grafik
Selecting the contacts for that notification rule is then further down.
Hai Elias,
Greetings & Thank you for your replay first.
Till now the mails are sending in two mail id’s. I have checked null mailer also, in nul mailer also showing only two mail id’s instead of 27 mail id. Can you please suggest any another option i am mistakenly changed or am missing.
Dear Elias,
Am attaching my settings for your reference to get my issue understand better and your suggestion.
& Null mailer details
