I am generating a small plugin for monitoring Veeam repositories, when I get the information from them I get it in bytes and the information shown in the summary and in the details is not transformed.
I have managed to transform it to GB or TB in the graphs through “~/local/share/check_mk/web/plugins/metrics/mymetric.py”.
I’ve made a script that gets the info in demo mode for testing, here I leave the pictures
Hi.
You see only the raw data from the local check. It’s only a value and will not calculated like in the metrics system. If you write a real check by using the CheckAPI than it works.
Rg, Christian
hi christian
after all this time I have my test plugin generated, now I have the same problem, I can not get the values to transform, I am trying to investigate in the files to see where the parameter can be but I consider myself unable to find it.
this is mi check function
this is the result
