Current User Configuration: LDAP > Attribute Sync Plugins - Roles - Normal monitoring user
LDAP discovered ‘testuser’ user is assigned to Contact Group: ‘testgrp’
The hosts that are preferred to be the only ones visible by the ‘testuser’ have
Contact Groups: ‘testgrp’
Permissions: ‘testgrp’
Preference is that only hosts assigned the ‘testgrp’ contact group would be visible. However, when the ‘testuser’ logs in, he is able to see all the hosts not just the ones in the ‘testgrp’.
Is there another section that has to be configured to only allow a user visibility of certain hosts?
Did you changed your “Global Settings” -> “Monitoring Core” -> “Authorization settings” to
“Host-/Servicegroups: Strict”?
You need this option to bind the visibility of a host to it’s contact group.
