Horizon VDIs Monitoring
Hello All,
I need to know if it is possible to monitor Horizon VDIs and where I can find the requirements for such a configuration.
Or if this is not possible.
Thanks in advance.
Regards.
Vix
Hi @VIX,
there are no official out of the box checks, especially for VMware Horizon. You can monitor the UAG Appliances with SNMP. But if you want a deeper implementation and monitoring, there are open source scripts you can utilize.
For example:
We have built our own local checks but I’m not allowed to release them. They are just for internal use. But with the examples provided it’s pretty easy to implement a solution.
Regards
Norm
