Freshly moved to 2.0 (what a mistake !? ). I am working on cleaning up all the troubles it made (10% of my services are stalled, yeah ! ).
One of the 2 big issues i have for now is related to ipmi and it’s failure.
CMK Agent fail on mgmt_ipmi.
Going with the command line report this :
OMD[xxx]:~/local/share/check_mk/checks$ cmk --debug -nv --checks=mgmt_ipmi yyy
WARNING: ‘–checks’ is deprecated in favour of option ‘detect-plugins’
Checkmk version 2.0.0
FETCHING DATA
[IPMIFetcher] Execute data source
File “/omd/sites/xxx/bin/cmk”, line 98, in
exit_status = modes.call(“–check”, None, opts, args)
File “/omd/sites/xxx/lib/python3/cmk/base/modes/init.py”, line 69, in call
return handler(*handler_args)
File “/omd/sites/xxx/lib/python3/cmk/base/modes/check_mk.py”, line 1616, in mode_check
return checking.do_check(
File “/omd/sites/xxx/lib/python3/cmk/base/decorator.py”, line 37, in wrapped_check_func
status, infotexts, long_infotexts, perfdata = check_func(hostname, *args, **kwargs)
File “/omd/sites/xxx/lib/python3/cmk/base/checking.py”, line 195, in do_check
fetcher_messages = list(
File “/omd/sites/xxx/lib/python3/cmk/base/checkers/_checkers.py”, line 246, in fetch_all
raw_data = source.fetch()
File “/omd/sites/xxx/lib/python3/cmk/base/checkers/_abstract.py”, line 163, in fetch
return fetcher.fetch(self.mode)
File “/omd/sites/xxx/lib/python3/cmk/fetchers/_base.py”, line 221, in fetch
return result.OK(self._fetch(mode))
File “/omd/sites/xxx/lib/python3/cmk/fetchers/_base.py”, line 250, in _fetch
raw_data = self._fetch_from_io(mode)
File “/omd/sites/xxx/lib/python3/cmk/fetchers/ipmi.py”, line 76, in _fetch_from_io
return AgentRawData(b"" + self._sensors_section() + self._firmware_section())
File “/omd/sites/xxx/lib/python3/cmk/fetchers/ipmi.py”, line 140, in _sensors_section
sdr = ipmi_sdr.SDR(self._command)
File “/omd/sites/xxx/lib/python3/pyghmi/ipmi/sdr.py”, line 634, in init
self.read_info()
File “/omd/sites/xxx/lib/python3/pyghmi/ipmi/sdr.py”, line 665, in read_info
self.get_sdr()
File “/omd/sites/xxx/lib/python3/pyghmi/ipmi/sdr.py”, line 740, in get_sdr
sdrrec = self.ipmicmd.raw_command(netfn=0x0a, command=0x23,
File “/omd/sites/xxx/lib/python3/pyghmi/ipmi/command.py”, line 500, in raw_command
rsp = self.ipmi_session.raw_command(netfn=netfn, command=command,
File “/omd/sites/xxx/lib/python3/pyghmi/ipmi/private/session.py”, line 779, in raw_command
self._send_ipmi_net_payload(netfn, command, data,
File “/omd/sites/xxx/lib/python3/pyghmi/ipmi/private/session.py”, line 819, in _send_ipmi_net_payload
data = bytearray(data)
TypeError: ‘float’ object cannot be interpreted as an integer
Happens this error also if you define this host as its own host und use the IPMI special agent?
The mgmt_ipmi had also some problems in version 1.6 and that’s the reason i only use the special agent.
Rule can be found under “IPMI Sensors via Freeipmi or IPMItool”.
I use management board config part of the host config and the ip is different from the host itself.
It was working fine on 1.6.
Mgmt board with snmp is working fine on 2.0.
On my side problem was with UCS blades/racks IPMI, it use ipmi v2 which isn’t used with cmk2.0 (no clue how magically it was working before)
Anyway, i moved to separate host and it’s mostly working now. I had to use some hosts with freeipmi and some with ipmi-tool
add fixes to the ipmi python code to ignore some ok messages.
Yeah, with the LAN_2_0 driver I’m able to see several values/services, half in “State Deasserted”. Is there any way to restore cmk1.6 functionality? Or the only thing I can do is to play with that rule to try various options (doesn’t seem to help a lot)?
