CMK version: 2.2.0p27
OS version: Oracle Linux 7
Hello, I would like to ask if it is possible to match hostnames case insensitively.
I have a CheckMK environment where hosts have upper, lower and sometimes camel case names. These hosts are VMware VMs. In the vCenter they also don’t have a uniform case spelling. Lastly the case spelling within the DNS is also not uniform.
The spelling itself (names/letters) are all the same. Just the case is different. For example in CheckMK a host name is “Myhost”. The same host is called “myHost” in vCenter and “MYHOST” in the DNS.
I like to find a solution how to easily (1) assign the correct piggyback data to the hosts and (2) prevent the hosts from appearing in the network scan, because the DNS responds with a different case spelling.
I have worked with the “hostname translation for piggybacked hosts” as well as the hostname translation in the network scan folder properties. But I just seem to be able to translate the hostnames for the piggyback / network scan results, but not for the CheckMK hostnames. I thought I could translate the piggyback / dns names to lowercase and then translate my CheckMK hostnames to lowercase as well and then compare. But apparently this is not possible, or is it?
I have about 250 hosts which are inconsistently named. So writing individual translations for each hostname is not really an option.
Thanks in advance!
Sven
