How can we monitor openshift Cluster Nodes in checkmk?. Does checkmk support openshift products?.
Direct OpenShift support is in development or testing at the moment.
You can ask @martin.hirschvogel about the status.
You can already monitor OpenShift at the moment. It has some limitations though which we are currently fixing. I will write a KB article on that and share that shortly.
The cluster collectors are currently not supported in OpenShift due to missing scc’s.
You can however still get a good status monitoring of your cluster, e.g. Pod status, Deployment replicas.
To get there, you need to adapt section 3 of the official how-to guide in our documentation as you only have to set-up a ServiceAccount with respective roles in OpenShift.
Setting up the RBAC to access the API.
- oc create namespace checkmk-monitoring
- oc apply -f https://raw.githubusercontent.com/tribe29/checkmk_kube_agent/main/deploy/kubernetes/checkmk-serviceaccount.yaml
- export TOKEN=$(oc get secret $(oc get serviceaccount checkmk -o=jsonpath=‘{.secrets[0].name}’ -n checkmk-monitoring) -n checkmk-monitoring -o=jsonpath=‘{.data.token}’ | base64 --decode);
- export CA_CRT=“$(oc get secret $(oc get serviceaccount checkmk -o=jsonpath=‘{.secrets[0].name}’ -n checkmk-monitoring) -n checkmk-monitoring -o=jsonpath=‘{.data.ca.crt}’ | base64 --decode)”;
After that, follow the steps in section 4 with the following exceptions.
4.1 You don’t have to retrieve the password again as you stored the password (token) before in $TOKEN.
4.2 You don’t have to retrieve the certificate again as you stored the password (token) before in $CA_CRT. Use echo "$CA_CRT" to retrieve it to preserve proper line breaks.
4.5 Do not configure the option “Enrich with usage data from Checkmk Cluster Collector”.
The KB article will be released soon.
EDIT: Unfortunately there are two secrets belonging to that serviceaccount. Typically the relevant one is the first one, which typically looks like checkmk-token-xyz12. You might have to change thus the number in .secrets[0] to .secrets[1]. I thus updated the export commands accordingly.
https://kb.checkmk.com/display/KB/Monitoring+OpenShift+with+Checkmk
EDIT: Fixed a copy&paste thingy in the KB article
