How to monitor GPU usage, temperature etc on Redhat systems .
what do you mean? please explain. Thank You!!
Likely you would write your own plugin. GPU inspection can vary based on GPU.
I want to monitor NVidia GPU monitoring, like GPU usage, temperature etc.
You might try out this:
https://exchange.checkmk.com/p/nvidia-smi-1
If this does not work, please read …
… start fixing the plugin and do not hesitate to ask here. I will happily update the article mentioned with the findings.
