Battery on HPSA1: Red (The physical element is failing)CRIT , HP Smart Array P220i Controller : Embedded : HPSA1: Red (The physical element is failing)CRIT , Battery on HPSA1: Red (The physical element is failing)CRIT , HP Smart Array P220i Controller : Embedded : HPSA1: Red (The physical element is failing)CRIT
I’d like to disable the battery check, or make it only a warning.
Especially for the ESX sensors, you can define for every sensor his own state.
In your case you use the complete name of the sensor (no regex allowed here i don’t know why) and set it’s status to good.
