How to add description on a host?
Is it possible to add a comment to a host? Something like when you create a rule and you can add a description
You can use the alias-field for comments.
regards, Franz
Not that I am aware of. Beside the alias, which I dont find in 2.0 currently :open_mouth: , you may use the following rules:
Host Contact Information
Its a free text.
Notes URL for Hosts
Could point to a wiki…
Hope that helps
Michael
If you’re talking about WATO, you could use a custom attribute for this.
So it would then look like this in WATO:
Not my topic but that`s what i searched for thanks!
The alias field is, for some obscure reason, hidden by default in 2.0:
But if you click the “Show more” it’s there:
Louis
