usermk
(User MK)
1
I execute WATO on certain host to found new services and when the process is finish I see that new “discovered hosts labels” appears. For example:
CHECK PLUGIN: esx_systeminfo
HOST LABELS: cmk/vsphere_object:vcenter
If I enter to the properties of this hosts inside “custom attributes” I didn’t found the previous label.
How can I assign this label to the host?
Thanks
There should be a button “Update host labels” in Service Discovery, right besides “Full scan”.
usermk
(User MK)
3
I click on “update host labels” and then apply the change.
Where can I found this label? On tag element inside hosts not found…
Labels and tags are not the same!
After cklicking on “Update host labels” (and activating changes), you should see the label(s) in the host view (“Status of Host …”).
For example, the monitoring server itself should have a label “cmk/check_mk_server:yes” which is discovered automatically.
system
(system)
Closed
5
