I’m facing an issue with the timezone settings in Checkmk. The graphs and timestamps in my monitoring system are currently displaying the wrong time, and I’m struggling to find where to adjust the timezone settings.
Could someone please guide me on how to change the timezone for the graphs and timestamps in Checkmk? I’m using OMD Checkmk.
The Checkmk server takes its time and timezone settings from the OS it is running on. That means if your OS got the wrong time, your Checkmk has it too.
You can change the time format in your global settings tho:
If you cannot adjust the timezone of the monitoring server you can set the TZ variable in $OMD_ROOT/etc/environment to a timezone of your choice.
Restart the site with omd restart and it will run in this timezone.
