How to configure for Monitoring Service for FileSystems
Hello all.
How you doing.
Could you please help me to know if checkmk has a way how to configure the FileSystems monitoring service and that it can spread.
Please let me know if you need more information.
Thanks in advance.
Best Regards.
I’m not sure if I understand the question correctly. Perhaps you can explain in different words and in more detail what you want to achieve.
Yes, Checkmk can monitor file systems, of course. Have a look at the Check Plug-Ins Catalog
and search that page for “filesystem” … available for a whole lot of different systems.
Like about any other check in Checkmk, these filesystem checks can be configured via rulesets including inheritance of parameters. See Host and service parameters - Understanding and using rules in Checkmk where the example even uses the filesystem check to demonstrate the advantages of rulesets :slight_smile:
