I am just wondering if it is possible to create reports from a customized view.
As example in my custom view i have 5 test und 10 production server.
I am searching for a simple and easy way to create reports for those. But i am not finding the right tool.
Is there a simple and easy how to or a hands on guide ? Because in the official documentation the information are very basic. Any ideas ?
Cheers Christian
I think you use the enterprise edition if you want to create reports. Is this right?
If it is so then you can create inside the report any custom view you want.
The possibilities are the same as to create a normal custom view.
Inside the report you can select the “Add Content” and then the drop down selection for “A Multisite view”.
Now you can define your view.
