Running 2.0.0p18 (CRE). I’m an Admin user but cannot see a way to delete a view I created. There has to be a way, right? What am I missing? Thanks.
In the left Customize-Menu you have a Views Link. There you can edit, copy and delete all custom views.
Cheers Jeronimo
So either this is a role/permission thing or more likely I did something wrong during view creation. Somehow the view became associated with one particular dashboard and munged things up. I think I am going to have to recreate the dashboard. Thanks.
If the view is part of a dashboard you have to edit the dashboard and remove the view there.
Yeah, it was part of the dashboard. Thanks you guys for the assist, each reply was helpful.
