Those 3 devices are monitored via SNMP. I already disabled the notifications for the Check_MK service on those hosts, but those events still show up in event console.
Whats the best way to disable the WARN for them? Based on what I read so far, timeouts might be the only way to disable those.
Or is there any better solution for this?
Or do I need to disable piggyback completely? (Never use piggyback data)
Yeah it turns ok between those checks, I just filtered to not show OK.
So is my only option to contact the vendor or is there any way to silence these events in cmk?
