**CMK version: 2.4.0p26 Enterprise Edition **
I’m a little desperate how to disable a https service check, that was enabled in the past.
I can still spot a connection to the target host, although I literally removed everything (host, checks) related to the target host.
root@lnzcheckmk01:~ # tcpdump -i any host 10.100.10.74 and port 443
11:24:32.186391 ens192 Out IP lnzcheckmk01.research.silicon-austria.com.40606 > VIHWEB01.siliconaustria.local.https: Flags [S] ..
The https check I had was time.silicon-austria.com , so VIHWEB01.siliconaustria.local seen is an alias. I still see these SYN packets every 5 minutes (and the webserver log also).
I also meanwhile removed the host time.silicon-austria.com in the setup, restarted checkmk, reloaded the core cmk -O .
And besides that, I see no http check anymore:
SAL@lnzcheckmk01:~/var/log $ cmk -N -v time.silicon-austria.com
# Created by Check_MK. Do not edit.
# time.silicon-austria.com
define host {
_ADDRESSES_4
_ADDRESSES_6
_ADDRESS_4 10.100.10.74
_ADDRESS_6
_ADDRESS_FAMILY 4
_TAGS / auto-piggyback cmk-agent ip-v4-only lan no-snmp prod site:SAL
__TAG_616464726573735F66616D696C79 69702D76342D6F6E6C79
__TAG_6167656E74 636D6B2D6167656E74
__TAG_637269746963616C697479 70726F64
__TAG_6E6574776F726B696E67 6C616E
__TAG_70696767796261636B 6175746F2D70696767796261636B
__TAG_73697465 53414C
__TAG_736E6D705F6473 6E6F2D736E6D70
address 10.100.10.74
alias time.silicon-austria.com
check_command check-mk-host-ping!-w 200.00,80.00% -c 500.00,100.00%
host_name time.silicon-austria.com
hostgroups check_mk
use check_mk_host
define service {
check_command check-mk-ping!-w 200.00,80.00% -c 500.00,100.00% 10.100.10.74
check_interval 1.0
contact_groups
service_description PING
use check_mk_pingonly
and
SAL@lnzcheckmk01:~ $ cmk -N -v VIHWEB01.siliconaustria.local
# VIHWEB01.siliconaustria.local
Updating IPv4 DNS cache for VIHWEB01.siliconaustria.local: 10.100.10.74
define host {
_ADDRESSES_4
_ADDRESSES_6
_ADDRESS_6
_ADDRESS_FAMILY 4
alias VIHWEB01.siliconaustria.local
host_name VIHWEB01.siliconaustria.local
hostgroups check_mk
use check_mk_host
define service {
check_interval 1.0
contact_groups
How can I stop the https check completely? Thanks
