CMK version:
2.1.0p24
OS version:
Debian 11
None
OMD[monitoring]:~$ cmk --debug -vvn MischiefDS01
Checkmk version 2.1.0p24
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Got lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
Released lock on /omd/sites/monitoring/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f00f946c5b0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(MischiefDS01, base_path=/omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 27 sec, allowed is 0 sec)
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Executing SNMP GET of .1.3.6.1.2.1.1.1.0 on MischiefDS01
=> [b'USW GigaBit Ethernet Switch, firmware 6.5.32.14509'] OCTETSTR
Getting OID .1.3.6.1.2.1.1.2.0: Executing SNMP GET of .1.3.6.1.2.1.1.2.0 on MischiefDS01
=> [b'.1.3.6.1.4.1.41112.1'] OBJECTID
Using cached OID .1.3.6.1.2.1.1.1.0: 'USW GigaBit Ethernet Switch, firmware 6.5.32.14509'
SNMP scan found snmp_uptime
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/snmp_scan_cache/MischiefDS01.192.168.1.2
Got lock on /omd/sites/monitoring/tmp/check_mk/snmp_scan_cache/MischiefDS01.192.168.1.2
Releasing lock on /omd/sites/monitoring/tmp/check_mk/snmp_scan_cache/MischiefDS01.192.168.1.2
Released lock on /omd/sites/monitoring/tmp/check_mk/snmp_scan_cache/MischiefDS01.192.168.1.2
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.1" on MischiefDS01
.1.3.6.1.2.1.2.2.1.1.1 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.2 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.3 => [b'3'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.2" on MischiefDS01
.1.3.6.1.2.1.2.2.1.2.1 => [b'lo'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.2 => [b'vtss.ifh'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.3 => [b'eth0'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.3" on MischiefDS01
.1.3.6.1.2.1.2.2.1.3.1 => [b'24'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.2 => [b'6'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.3 => [b'6'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.5" on MischiefDS01
.1.3.6.1.2.1.2.2.1.5.1 => [b'10000000'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.2 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.3 => [b'0'] 'GAUGE'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.8" on MischiefDS01
.1.3.6.1.2.1.2.2.1.8.1 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.2 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.3 => [b'1'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.6" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.6.1000001 => [b'216926538841'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.1000002 => [b'1716655530'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.1000003 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.1000004 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.1000005 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.1000006 => [b'447178257'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.1000007 => [b'9652918636'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.1000008 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.1005001 => [b'218643194371'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.7" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.7.1000001 => [b'169677589'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.1000002 => [b'9761317'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.1000003 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.1000004 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.1000005 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.1000006 => [b'5289969'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.1000007 => [b'67280742'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.1000008 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.1005001 => [b'179438906'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.8" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.8.1000001 => [b'219578'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.1000002 => [b'1190791'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.1000003 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.1000004 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.1000005 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.1000006 => [b'26984'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.1000007 => [b'487212'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.1000008 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.1005001 => [b'1410369'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.9" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.9.1000001 => [b'187681'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.1000002 => [b'37682'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.1000003 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.1000004 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.1000005 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.1000006 => [b'6013'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.1000007 => [b'167513'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.1000008 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.1005001 => [b'225363'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.13" on MischiefDS01
.1.3.6.1.2.1.2.2.1.13.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.2 => [b'16'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.3 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.14" on MischiefDS01
.1.3.6.1.2.1.2.2.1.14.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.3 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.10" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.10.1000001 => [b'4581479039'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.1000002 => [b'5371879541'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.1000003 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.1000004 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.1000005 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.1000006 => [b'17277121954'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.1000007 => [b'201773579601'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.1000008 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.1005001 => [b'9953358580'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.11" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.11.1000001 => [b'35950549'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.1000002 => [b'36326959'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.1000003 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.1000004 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.1000005 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.1000006 => [b'11423903'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.1000007 => [b'168056979'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.1000008 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.1005001 => [b'72277508'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.12" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.12.1000001 => [b'457763'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.1000002 => [b'433295'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.1000003 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.1000004 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.1000005 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.1000006 => [b'1501064'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.1000007 => [b'1058183'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.1000008 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.1005001 => [b'891058'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.13" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.13.1000001 => [b'134434'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.1000002 => [b'41003'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.1000003 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.1000004 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.1000005 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.1000006 => [b'394732'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.1000007 => [b'232072'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.1000008 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.1005001 => [b'175437'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.19" on MischiefDS01
.1.3.6.1.2.1.2.2.1.19.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.2 => [b'1'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.3 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.20" on MischiefDS01
.1.3.6.1.2.1.2.2.1.20.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.3 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.21" on MischiefDS01
.1.3.6.1.2.1.2.2.1.21.1 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.2 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.3 => [b'0'] 'GAUGE'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.18" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.18.1000001 => [b'Gi 1/1'] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.1000002 => [b'Gi 1/2'] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.1000003 => [b'Gi 1/3'] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.1000004 => [b'Gi 1/4'] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.1000005 => [b'Gi 1/5'] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.1000006 => [b'Gi 1/6'] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.1000007 => [b'Gi 1/7'] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.1000008 => [b'Gi 1/8'] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.1005001 => [b'LAG 1005001'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.6" on MischiefDS01
.1.3.6.1.2.1.2.2.1.6.1 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.2 => [b'*K\xba\x16\x0e~'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.3 => [b'\xfc\xec\xda\xbf1-'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.15" on MischiefDS01
.1.3.6.1.2.1.31.1.1.1.15.1000001 => [b'1000'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.1000002 => [b'1000'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.1000003 => [b'10'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.1000004 => [b'10'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.1000005 => [b'10'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.1000006 => [b'1000'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.1000007 => [b'1000'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.1000008 => [b'10'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.1005001 => [b'2000'] 'GAUGE'
Executing BULKWALK of ".1.3.6.1.2.1.1.1" on MischiefDS01
.1.3.6.1.2.1.1.1.0 => [b'USW GigaBit Ethernet Switch, firmware 6.5.32.14509'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.4" on MischiefDS01
.1.3.6.1.2.1.1.4.0 => [b'Owner'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.5" on MischiefDS01
.1.3.6.1.2.1.1.5.0 => [b'MischiefDS01'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.6" on MischiefDS01
.1.3.6.1.2.1.1.6.0 => [b'MischiefRC0106U'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.3" on MischiefDS01
.1.3.6.1.2.1.1.3.0 => [b'18540375'] 'TICKS'
Executing BULKWALK of ".1.3.6.1.2.1.25.1.1" on MischiefDS01
Executing SNMP GET of .1.3.6.1.2.1.25.1.1 on MischiefDS01
=> [None] NOSUCHOBJECT
Write data to cache file /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/MischiefDS01
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/MischiefDS01
Got lock on /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/MischiefDS01
Releasing lock on /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/MischiefDS01
Released lock on /omd/sites/monitoring/tmp/check_mk/data_source_cache/snmp/checking/MischiefDS01
[cpu_tracking] Stop [7f00f946c5b0 - Snapshot(process=posix.times_result(user=0.04999999999999993, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.3999999985098839))]
[cpu_tracking] Start [7f00f949af40]
[PiggybackFetcher] Fetch with cache settings: NoCache(MischiefDS01, base_path=/omd/sites/monitoring/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'MischiefDS01'. Skip processing.
No piggyback files for '192.168.1.2'. Skip processing.
[cpu_tracking] Stop [7f00f949af40 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
No persisted sections
-> Add sections: ['if64', 'snmp_info', 'snmp_uptime']
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f00f94ca2b0]
value store: synchronizing
Trying to acquire lock on /omd/sites/monitoring/tmp/check_mk/counters/MischiefDS01
Got lock on /omd/sites/monitoring/tmp/check_mk/counters/MischiefDS01
Releasing lock on /omd/sites/monitoring/tmp/check_mk/counters/MischiefDS01
Released lock on /omd/sites/monitoring/tmp/check_mk/counters/MischiefDS01
Interface 1 [lo], (up), Speed: 10 MBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface 2 [vtss.ifh], (up), MAC: 2A:4B:BA:16:0E:7E, Speed: unknown, In: 0.00 B/s, Out: 0.00 B/s
Interface 3 [eth0], (up), MAC: FC:EC:DA:BF:31:2D, Speed: unknown, In: 0.00 B/s, Out: 0.00 B/s
SNMP Info USW GigaBit Ethernet Switch, firmware 6.5.32.14509, MischiefDS01, MischiefRC0106U, Owner
Uptime Up since Mar 20 2023 17:47:09, Uptime: 2 days 3 hours
[cpu_tracking] Stop [7f00f94ca2b0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[snmp] Success, execution time 0.4 sec | execution_time=0.400 user_time=0.050 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.350 cmk_time_agent=0.000
Wow, that’s a long paste.
I am trying to run a discovery to get the interfaces from OID .1.3.6.1.2.1.31.1.1.1.18 which is found by the CLI, but I simply cannot seem to make a rule to discover these interfaces at all.
The only interfaces that are discovered in WOTA are what you see in the output, but also here:
The interfaces are located at .1.3.6.1.2.1.31.1.1.1.18 and states at .1.3.6.1.2.1.10.7.2.1.19 (where ‘3’ appears to be ‘up’ and ‘1’ is ‘down’ (I have not researched this part of the MIB, admittedly)). The first part is found in the bulk pasted above, but the second one is not. The first can also be found in 1.3.6.1.2.1.31.1.1.1.1 but I don’t even see that in the bulk:
iso.3.6.1.2.1.31.1.1.1.1.1000001 = STRING: "GigabitEthernet 1/1"
iso.3.6.1.2.1.31.1.1.1.1.1000002 = STRING: "GigabitEthernet 1/2"
iso.3.6.1.2.1.31.1.1.1.1.1000003 = STRING: "GigabitEthernet 1/3"
iso.3.6.1.2.1.31.1.1.1.1.1000004 = STRING: "GigabitEthernet 1/4"
iso.3.6.1.2.1.31.1.1.1.1.1000005 = STRING: "GigabitEthernet 1/5"
iso.3.6.1.2.1.31.1.1.1.1.1000006 = STRING: "GigabitEthernet 1/6"
iso.3.6.1.2.1.31.1.1.1.1.1000007 = STRING: "GigabitEthernet 1/7"
iso.3.6.1.2.1.31.1.1.1.1.1000008 = STRING: "GigabitEthernet 1/8"
iso.3.6.1.2.1.31.1.1.1.1.1005001 = STRING: "Link Aggregations 1005001"
How can I make a rule to also discover these interfaces?
Thanks for your help!
