I’ve configured Checkmk with my hosts and services. All my hosts are currently up, but some services are in a critical state. However, I would like to receive sound alerts only when a host goes down.
Right now, the sound notifications keep going off all the time due to critical services, which is overwhelming and ineffective.
How can I configure Checkmk to trigger sound alerts only for host down events?
I don’t know how to do that, it seems like there’s only an off/on option in raw I’m running.
Thought of a workaround.
In Nagvis you can set mp3 files for certain states.
make a view in Nagvis with all of your hosts you want an alert from
upload silent mp3 files in the states you don’t want
turn on sound in Nagvis
Maybe a similar approach is also possible in Checkmk itself, but haven’t investigated that.
EDIT:
A quick look shows that Checkmk wav files can be found in /omd/sites/[site name]/share/check_mk/web/htdocs/sounds/.
So maybe if you put silent wav files for unwanted states in /omd/sites/[site name]/local/share/check_mk/web/htdocs/sounds/ it hopefully overrides those system resources.
