How can I exclude e.g. a host using regex? I’m working on a event rule where I want to exclude specific hosts. I tried regex in the “Match Host” field like .*(?!pattern).* but it doesn’t seem to work. Does anybody know how to do it?
Thanks
Thanks
Albeit there are ways to create a regex that matches lines that do not contain a certain string, I wouldn’t recommend that because it is cumbersome and not exactly easy to understand.
I would go with two rules: One that matches your hosts and does what you want and another rule before that one that says “stop processing” if the hostname matches some pattern:
Here the order is important: the “skip” rule must come first, followed by the rule which actually does something:
Hi.
Did you try this one: ^(?!pattern)$
If you like to negate more than one: ^(?!pattern1|pattern2|…)$
Regards,
Christian
Apparently not, that worked. Thanks
Thanks for the suggestion, that would probably also work
