is it correct that plugins from checkmk extension only can be delivered via agent bakery? So it is not possible to download just the plugin like it is possible for the integrated plugins on https://<SITE-URL>/check_mk/agents/plugins/ ?
Kind regards
Mathias
Hi @matze218,
You can also get installed extensions in
https://SITE-URL/check_mk/local/agents/plugins
does this answer your questions ?
Cheers,
@ricardoftribeiro Hi, that was exactly what I was looking for. Because now I can download it like the other plugins. Otherwise I have to build an agent and rewrite the role to download Agent by “hostname” via API. Thank you!
