how to ignore some of status detail
Hi
how to ignore or do not show status detail
“(up) MAC: 00:2A:6A:A6:49:27, 4.29 Gbit/s, In: 959.03 kB/s (0.2%), in-errors: 2.45%CRIT >= 0.1%, Out: 1.92 kB/s (0.0%)”
or
" 00:2A:6A:A6:49:0E, 4.29 Gbit/s, In: 4.05 kB/s (0.0%), Out: 3.52 kB/s (0.0%), out-errors: 0.28%CRIT >= 0.1%"
plz refer to the photo
Click on the three bars icon → go to the parameters and add a rule to tolerate a higher error count:
or: have your network guys fix the network :slight_smile: having that many interfaces with errors could have consequences if these interfaces are actually used for production traffic.
hi @komeylgivechi
welcome to the forum!
What do you want to achieve? A shorter / blank service description? Which part do you want to remove? The MAC address? The Crit part?
Also: What’s your motivation for this request?
Best
Elias
I want the error with this specification related to the speed of the interfaces not to be displayed
Hi @komeylgivechi
thanks for the additional explanation.
As @gstolz mentioned, the best way would probably be to solve the actual problem in the network that causes the service to go CRIT. Typically, if Checkmk shows something as a problem, there’s a reason for that…
But, if you think the threshold is too sensitive, then you can, as also mentioned by @gstolz , tune the thresholds via “Parameters for this service”
If you think the service is completely irrelevant, you can always remove it permanently (Disabled Services).
If you want to modify the service description to show something different, then you would need to make a /local copy of the plugin and modify the code.
Hope this helps.
Elias
