Hi
when I use the ARISTA-ENTITY-SENSOR-MIB, I can find the following…
entPhysicalDescr
.1.3.6.1.2.1.47.1.1.1.1.2.100601111 = STRING: Fan Tray 1 Fan 1 Sensor 1
.1.3.6.1.2.1.47.1.1.1.1.2.100602111 = STRING: Fan Tray 2 Fan 1 Sensor 1
.1.3.6.1.2.1.47.1.1.1.1.2.100603111 = STRING: Fan Tray 3 Fan 1 Sensor 1
.1.3.6.1.2.1.47.1.1.1.1.2.100604111 = STRING: Fan Tray 4 Fan 1 Sensor 1
but from the example it looks like all info is collected from 1 base OID…
I think I’m looking at .1.3.6.1.2.1.47.1.1.1.1.2. and .1.3.6.1.2.1.99.1.1.1.5. for these 2 values?
It does depend however on what else this OIDs hold. So does an snmpwalk on eg. .1.3.6.1.2.1.99.1.1.1.5 return anything beside 100601111, 100602111 etc.?
I think this is a little bit more complicated.
You need to fetch also the OID_END (100601111, 100602111 and so on). This number is needed to join then booth lists you fetch.
Good example is the https://github.com/tribe29/checkmk/blob/master/checks/cmciii check - info section starting at line 209
Your parse function don’t need to be as complex as the cmciii check but you need to join booth lists to one single list or dictionary (dictionary would be preferred).
