Hello Team,
There is requirement to install perl module inside check_mk site. Is there any procedure available to install perl module inside check_mk site ?
Thanks in Advance
Regards,
Dinesh
Hello Team,
Thanks in Advance
Regards,
Dinesh
You can install Perl modules with cpanminus
as the site user, e.g.
cpanm --verbose Net::SNMP
This will install the Net::SNMP module below ~/local/lib/perl5
and make it accessible for the site user.
Thanks @Dirk for replying. I have tried the command provided but cpanm command is not available.
OMD[prod1]:~$ cpanm --verbose Net::SNMP
-bash: cpanm: command not found
Regards,
Dinesh
sudo apt install cpanminus
