How to label multiple users to a host
New to CMK, discovering 2.0.0p16 (CRE), trying to find out how to do things.
To keep track which client machine(s) has which local users, I thought I add users as multiple host labels in the form user:username1, user:username2.
Manually at first and perhaps later add them dynamically with a custom inventory plugin using something like:
Get-WmiObject -Class Win32_UserAccount -Filter "Disabled=False" | Select Name
But I am already failing in the manual adding part of host labels, since there can only be 1 unique key per host. So adding user:username1 is not a problem, but adding user:username2 to the same host is not possible.
So how can I ‘label’ multiple users to a host instead?
Hopefully it is possible in a way so I can filter for it in a view.
Make your labels in the form user/username1:yes and user/username2:yes.
I thought about making the value as key, like username1:true, but then I wouldn’t have an organised collection of users to filter on. This solves that too.
Thanks!
