JDamian
November 22, 2023, 11:54am
1
Hi
For inventory purposes, I’m trying to get Check_MK to monitor de OID 1.3.6.1.2.1.47.1.1.1.1.2.1 of some Fortigate equipment.
SNMPv2-SMI::mib-2.47.1.1.1.1.2.1 = STRING: "Fortinet FGT_60F, HW Serial#: FGT60FTKxxxxJJV6"
How can I do that?
UPDATE : I’m going to use the Nagios plugin check_snmp by creating a rule using
check_snmp -H $HOSTADDRESS$ -o 1.3.6.1.2.1.47.1.1.1.1.2.1 -P 3 -L authPriv -a SHA -x AES -U XXXX -A YYYYYY -X ZZZZZ
What other VALUES similar to $HOSTADDRESS$ from HOST configuration are available to replace XXXX, YYYYY and ZZZZZ ?
Best regards
k.mala
(Kean)
November 22, 2023, 2:25pm
2
What worked for me is using the Check SNMP OID Rulset from the CheckMK exchange.
We use it to monitor Site-to-Site VPN Tunnels on our Firewalls:
Checkmk Exchange
It’s very easy to set up even though it has a teeny tiny bug:
Just make sure you have that unchecked and it works perfectly : )
Also dont forget to import the vendor MIB files.
Regards
Kean
system
(system)
Closed
November 21, 2024, 2:26pm
3
