Hi
I have to monitor an Apache CouchDB, (a non-relational data base, which, frankly, I never heard about until 5 days ago)
Is there any plugin in Check_MK to monitor CouchDB?
Best regards.
Hi
Best regards.
Hi @JDamian,
a plugin for checkmk doesn’t exist. A quick search for and there is a quite old nagios plugin (2013) and slightly newer local check (2015) for checkmk agents.
Thank you, @tosch.
I knew the plugin nagios but I had not found the local check version.
I’ll have to do some changes but I think it will be useful
