What is the way to monitor apache kafka server in checkmk.
what are the plugins and services to use monitor apachekafka ?
Hi.
Yiou need to identify your need. First of all you need to install the CheckMK Agent. Then you should check the needed processes of Kafka. If Kafka has a monitoring API, you can try to get informations about Kafka. Otherwise you can try to implement Jolokia to wath to your application.
RG,
Christian
i have apache kafka in my system but need to monitor kafka what is the procedure ?
i need to monitor apache kafka status for that what is the procedure ?
can anyone explain ?
