How to monitor AWS URL with Check_mk?
Hello All,
I need to monitor two URLs hosted on Amazon with Check_mk, I wanted to add the page name ftptransfer.xxxx.com but the IP is an amazon endpoint and it does not respond to ping. Once I can configure it, I must monitor port 21.
Could you guide me on how I can achieve this monitoring?
Thanks in advance.
Victor Pineda
With the ruleset “Host check command” you can define a different host check and must not rely on ICMP for the host to be up.
Hi R.Sander,
Thanks for your response.
Im trying to use the check ftp service to monitor a ftp service hosted on AWS, im defined the port 21 on the rule, and attached to a host that i creted with the name of the same endpoint, but i dont know if this is the correct way, because when i check the host i received this error:
Can some one can help me ? thank you
Regards.
Victor Pineda
Well, the hostname cannot be resolved using DNS.
