How to monitor Hyper-V in checkmk Step by Step
I need help to know How to monitor Hyper-V in a windows server.
I downloaded these two plugins:
  • hyperv_vms
  • hyperv_vms_guestinfos
I put these two files in the server in the next path:
C:\Program Files (x86)\checkmk\service\plugins
Then I also create a rule called:
Microsoft Hyper-V Server VM state
Then I run a discovery but nothing happen.
Can someone explain to me what am I missing?
It would be incredible if someone could tell me the steps in order to monitor hyper-v
Thanks
That’s the wrong place. Since 1.6 agent version you need to place the plugins inside "C:\ProgramData\checkmk\agent\plugins". Then you should see some information inside the agent output.
Don’t expect too much from this output it is very rudimentary. I had a own extended HyperV monitoring running in my systems. But no time to port it completely to 2.1. My version had nearly the same information level as the ESX checks.
Hi Andreas,
I put the plugins in “C:\ProgramData\checkmk\agent\plugins” but nothing is showed:
Should I modify something else? Any file or something?
No plugin output inside the agent output?
Hi Andreas,
Im not sure if this is the output, this is what shows when agent runs:
<<<check_mk>>>
Version: 2.0.0p17
BuildDate: Dec 7 2021
AgentOS: windows
Hostname: HYPERVHOST-1
Architecture: 64bit
WorkingDirectory: C:\Windows\system32
ConfigFile: C:\Program Files (x86)\checkmk\service\check_mk.yml
LocalConfigFile: C:\ProgramData\checkmk\agent\check_mk.user.yml
AgentDirectory: C:\Program Files (x86)\checkmk\service
PluginsDirectory: C:\ProgramData\checkmk\agent\plugins
StateDirectory: C:\ProgramData\checkmk\agent\state
ConfigDirectory: C:\ProgramData\checkmk\agent\config
TempDirectory: C:\ProgramData\checkmk\agent\tmp
LogDirectory: C:\ProgramData\checkmk\agent\log
SpoolDirectory: C:\ProgramData\checkmk\agent\spool
LocalDirectory: C:\ProgramData\checkmk\agent\local
OnlyFrom:
<<<wmi_cpuload:sep(124)>>>
[system_perf]
AlignmentFixupsPersec|Caption|ContextSwitchesPersec|Description|ExceptionDispatchesPersec|FileControlBytesPersec|FileControlOperationsPersec|FileDataOperationsPersec|FileReadBytesPersec|FileReadOperationsPersec|FileWriteBytesPersec|FileWriteOperationsPersec|FloatingEmulationsPersec|Frequency_Object|Frequency_PerfTime|Frequency_Sys100NS|Name|PercentRegistryQuotaInUse|PercentRegistryQuotaInUse_Base|Processes|ProcessorQueueLength|SystemCallsPersec|SystemUpTime|Threads|Timestamp_Object|Timestamp_PerfTime|Timestamp_Sys100NS|WMIStatus
0||2554795745||4300564|218354563728|1107824208|888246219|1666797679364|631436558|466535589254|256809661|0|10000000|2143274|10000000||98173108|4294967295|62|0|928075714|133109429204851825|1308|133124071971088494|3138248178613|133124269971080000|OK
[computer_system]
AdminPasswordStatus|AutomaticManagedPagefile|AutomaticResetBootOption|AutomaticResetCapability|BootOptionOnLimit|BootOptionOnWatchDog|BootROMSupported|BootupState|Caption|ChassisBootupState|CreationClassName|CurrentTimeZone|DaylightInEffect|Description|DNSHostName|Domain|DomainRole|EnableDaylightSavingsTime|FrontPanelResetStatus|HypervisorPresent|InfraredSupported|InitialLoadInfo|InstallDate|KeyboardPasswordStatus|LastLoadInfo|Manufacturer|Model|Name|NameFormat|NetworkServerModeEnabled|NumberOfLogicalProcessors|NumberOfProcessors|OEMLogoBitmap|OEMStringArray|PartOfDomain|PauseAfterReset|PCSystemType|PCSystemTypeEx|PowerManagementCapabilities|PowerManagementSupported|PowerOnPasswordStatus|PowerState|PowerSupplyState|PrimaryOwnerContact|PrimaryOwnerName|ResetCapability|ResetCount|ResetLimit|Roles|Status|SupportContactDescription|SystemStartupDelay|SystemStartupOptions|SystemStartupSetting|SystemType|ThermalState|TotalPhysicalMemory|UserName|WakeUpType|Workgroup|WMIStatus
3|1|1|1|||1|Normal boot|HYPERVHOST-1|3|Win32_ComputerSystem|330||AT/AT COMPATIBLE|HYPERVHOST-1|amefird.local|3|1|3|1|0|||3||HP|ProLiant DL380p Gen8|HYPERVHOST-1||1|32|2|||1|-1|1|1|||3|0|3||Windows User|1|65535|65535||OK|||||x64-based PC|3|68683169792||6||OK
1464230
MemTotal: 67073408 kB
MemFree: 21454856 kB
SwapTotal: 9961472 kB
SwapFree: 10020548 kB
PageTotal: 77034880 kB
PageFree: 31475404 kB
VirtualTotal: 137438953344 kB
VirtualFree: 137438857460 kB
<<fileinfo:sep(124)>>
1667933597
[[[Application]]]
[[[HardwareEvents]]]
[[[Internet Explorer]]]
[[[Key Management Service]]]
[[[Security]]]
[[[System]]]
[[[Windows PowerShell]]]
AeLookupSvc stopped/demand Application Experience
ALG stopped/demand Application Layer Gateway Service
AppIDSvc stopped/demand Application Identity
Appinfo running/demand Application Information
AppMgmt stopped/demand Application Management
AppReadiness stopped/demand App Readiness
AppXSvc stopped/demand AppX Deployment Service (AppXSVC)
AudioEndpointBuilder stopped/demand Windows Audio Endpoint Builder
Audiosrv stopped/demand Windows Audio
BFE running/auto Base Filtering Engine
BITS running/demand Background Intelligent Transfer Service
BrokerInfrastructure running/auto Background Tasks Infrastructure Service
Browser stopped/disabled Computer Browser
CertPropSvc running/demand Certificate Propagation
CheckMkService running/auto Check MK Service
COMSysApp stopped/demand COM+ System Application
CryptSvc running/auto Cryptographic Services
CylanceSvc running/auto Cylance Unified Agent
CyOptics running/auto Cylance Optics
DcomLaunch running/auto DCOM Server Process Launcher
defragsvc stopped/demand Optimize drives
DeviceAssociationService stopped/demand Device Association Service
DeviceInstall running/demand Device Install Service
Dhcp running/auto DHCP Client
DiagTrack running/auto Diagnostics Tracking Service
Dnscache running/auto DNS Client
dot3svc stopped/demand Wired AutoConfig
DPS running/auto Diagnostic Policy Service
DsmSvc stopped/demand Device Setup Manager
Eaphost stopped/demand Extensible Authentication Protocol
EFS stopped/demand Encrypting File System (EFS)
EventLog running/auto Windows Event Log
EventSystem running/auto COM+ Event System
fdPHost stopped/demand Function Discovery Provider Host
FDResPub stopped/demand Function Discovery Resource Publication
FontCache running/auto Windows Font Cache Service
FontCache3.0.0.0 stopped/demand Windows Presentation Foundation Font Cache 3.0.0.0
GoogleChromeElevationService stopped/demand Google Chrome Elevation Service (GoogleChromeElevationService)
gpsvc running/auto Group Policy Client
gupdate stopped/auto Google Update Service (gupdate)
gupdatem stopped/demand Google Update Service (gupdatem)
hidserv stopped/demand Human Interface Device Service
hkmsvc stopped/demand Health Key and Certificate Management
IEEtwCollectorService stopped/demand Internet Explorer ETW Collector Service
IKEEXT running/auto IKE and AuthIP IPsec Keying Modules
iphlpsvc running/auto IP Helper
KeyIso running/demand CNG Key Isolation
KPSSVC stopped/demand KDC Proxy Server service (KPS)
KtmRm stopped/demand KtmRm for Distributed Transaction Coordinator
LanmanServer running/auto Server
LanmanWorkstation running/auto Workstation
lltdsvc stopped/demand Link-Layer Topology Discovery Mapper
lmhosts running/auto TCP/IP NetBIOS Helper
LSM running/auto Local Session Manager
MMCSS stopped/demand Multimedia Class Scheduler
MpsSvc running/auto Windows Firewall
MSDTC running/auto Distributed Transaction Coordinator
MSiSCSI stopped/demand Microsoft iSCSI Initiator Service
msiserver stopped/demand Windows Installer
napagent stopped/demand Network Access Protection Agent
NcaSvc stopped/demand Network Connectivity Assistant
Netlogon running/auto Netlogon
Netman stopped/demand Network Connections
netprofm running/demand Network List Service
NetTcpPortSharing stopped/disabled Net.Tcp Port Sharing Service
NlaSvc running/auto Network Location Awareness
nsi running/auto Network Store Interface Service
PerfHost stopped/demand Performance Counter DLL Host
pla stopped/demand Performance Logs & Alerts
PlugPlay running/demand Plug and Play
PolicyAgent running/demand IPsec Policy Agent
Power running/auto Power
PrintNotify stopped/demand Printer Extensions and Notifications
ProfSvc running/auto User Profile Service
RasAuto stopped/demand Remote Access Auto Connection Manager
RasMan stopped/demand Remote Access Connection Manager
RemoteAccess stopped/disabled Routing and Remote Access
RemoteRegistry running/auto Remote Registry
RpcEptMapper running/auto RPC Endpoint Mapper
RpcLocator stopped/demand Remote Procedure Call (RPC) Locator
RpcSs running/auto Remote Procedure Call (RPC)
RSoPProv stopped/demand Resultant Set of Policy Provider
sacsvr stopped/demand Special Administration Console Helper
SamSs running/auto Security Accounts Manager
SCardSvr stopped/disabled Smart Card
ScDeviceEnum stopped/demand Smart Card Device Enumeration Service
Schedule running/auto Task Scheduler
SCPolicySvc stopped/demand Smart Card Removal Policy
seclogon stopped/demand Secondary Logon
SENS running/auto System Event Notification Service
SessionEnv running/demand Remote Desktop Configuration
SharedAccess stopped/demand Internet Connection Sharing (ICS)
ShellHWDetection stopped/auto Shell Hardware Detection
smphost stopped/demand Microsoft Storage Spaces SMP
SNMPTRAP stopped/demand SNMP Trap
Spooler running/auto Print Spooler
sppsvc stopped/auto Software Protection
SSDPSRV stopped/disabled SSDP Discovery
SstpSvc stopped/demand Secure Socket Tunneling Protocol Service
svsvc stopped/demand Spot Verifier
swprv stopped/demand Microsoft Software Shadow Copy Provider
SysMain stopped/demand Superfetch
SystemEventsBroker running/auto System Events Broker
Tanium_Client running/auto Tanium Client
TaniumDriverSvc running/auto Tanium Driver Service
TapiSrv stopped/demand Telephony
TermService running/demand Remote Desktop Services
Themes running/auto Themes
THREADORDER stopped/demand Thread Ordering Server
TieringEngineService stopped/demand Storage Tiers Management
TrkWks running/auto Distributed Link Tracking Client
TrustedInstaller stopped/demand Windows Modules Installer
tvnserver running/auto TightVNC Server
UALSVC running/auto User Access Logging Service
UI0Detect stopped/demand Interactive Services Detection
UmRdpService running/demand Remote Desktop Services UserMode Port Redirector
upnphost stopped/disabled UPnP Device Host
VaultSvc stopped/demand Credential Manager
vds stopped/demand Virtual Disk
vmicguestinterface stopped/demand Hyper-V Guest Service Interface
vmicheartbeat stopped/demand Hyper-V Heartbeat Service
vmickvpexchange stopped/demand Hyper-V Data Exchange Service
vmicrdv stopped/demand Hyper-V Remote Desktop Virtualization Service
vmicshutdown stopped/demand Hyper-V Guest Shutdown Service
vmictimesync stopped/demand Hyper-V Time Synchronization Service
vmicvss stopped/demand Hyper-V Volume Shadow Copy Requestor
vmms running/auto Hyper-V Virtual Machine Management
VSS stopped/demand Volume Shadow Copy
W32Time running/auto Windows Time
Wcmsvc running/auto Windows Connection Manager
WcsPlugInService stopped/demand Windows Color System
WdiServiceHost stopped/demand Diagnostic Service Host
WdiSystemHost stopped/demand Diagnostic System Host
Wecsvc stopped/demand Windows Event Collector
WEPHOSTSVC stopped/demand Windows Encryption Provider Host Service
wercplsupport stopped/demand Problem Reports and Solutions Control Panel Support
WerSvc stopped/demand Windows Error Reporting Service
WinHttpAutoProxySvc stopped/demand WinHTTP Web Proxy Auto-Discovery Service
Winmgmt running/auto Windows Management Instrumentation
WinRM running/auto Windows Remote Management (WS-Management)
wmiApSrv stopped/demand WMI Performance Adapter
WPDBusEnum stopped/demand Portable Device Enumerator Service
WSService stopped/demand Windows Store Service (WSService)
wuauserv stopped/demand Windows Update
wudfsvc stopped/demand Windows Driver Foundation - User-mode Driver Framework
<<<dotnet_clrmemory:sep(124)>>>
AllocatedBytesPersec|Caption|Description|FinalizationSurvivors|Frequency_Object|Frequency_PerfTime|Frequency_Sys100NS|Gen0heapsize|Gen0PromotedBytesPerSec|Gen1heapsize|Gen1PromotedBytesPerSec|Gen2heapsize|LargeObjectHeapsize|Name|NumberBytesinallHeaps|NumberGCHandles|NumberGen0Collections|NumberGen1Collections|NumberGen2Collections|NumberInducedGC|NumberofPinnedObjects|NumberofSinkBlocksinuse|NumberTotalcommittedBytes|NumberTotalreservedBytes|PercentTimeinGC|PercentTimeinGC_Base|ProcessID|PromotedFinalizationMemoryfromGen0|PromotedMemoryfromGen0|PromotedMemoryfromGen1|Timestamp_Object|Timestamp_PerfTime|Timestamp_Sys100NS|WMIStatus
5333834071024|||371|0|2143274|10000000|16777216|588464|539896|532584|221076064|197086240|Global|418702200|11958|213539|43880|5580|43|37|156|446324736|939503616|1219153|4294967295|0|361684|588464|532584|0|3138248543348|133124269972800000|OK
1701309976600|||186|0|2143274|10000000|6291456|414304|397136|532584|52776464|8552144|CyOptics|61725744|6667|194467|41256|4852|0|4|71|69357568|402644992|10980|25968094|2128|325762|414304|532584|0|3138248543348|133124269972800000|OK
965607058912|||185|0|2143274|10000000|10485760|174160|142760|0|168299600|188534096|CylanceSvc|356976456|5291|19072|2624|728|43|33|85|376967168|536858624|13433|92714140|1336|35922|174160|0|0|3138248543348|133124269972800000|OK
<<df:sep(9)>>
C:\ NTFS 332519420 263964776 68554644 80% C:
New_Volume NTFS 419430396 409116772 10313624 98% D:
New_Volume NTFS 419430396 402829368 16601028 97% E:
<<<winperf_phydisk>>>
1667933597.32 234 2143274
2 instances: 0_C:_D:_E: _Total
-36 0 0 rawcount
-34 61924610228000 61924610228000 type(20570500)
-34 133124071973119817 133124071973119817 type(40030500)
1166 61924610228000 61924610228000 type(550500)
-32 11877137551000 11877137551000 type(20570500)
-32 133124071973119817 133124071973119817 type(40030500)
1168 11877137551000 11877137551000 type(550500)
-30 50047472677000 50047472677000 type(20570500)
-30 133124071973119817 133124071973119817 type(40030500)
1170 50047472677000 50047472677000 type(550500)
-28 691761540 691761540 average_timer
-28 1108578125 1108578125 average_base
-26 2975371516 2975371516 average_timer
-26 912786466 912786466 average_base
-24 2011357320 2011357320 average_timer
-24 195791659 195791659 average_base
-22 1108578125 1108578125 counter
-20 912786466 912786466 counter
-18 195791659 195791659 counter
-16 10541749867008 10541749867008 bulk_count
-14 7521800519168 7521800519168 bulk_count
-12 3019949347840 3019949347840 bulk_count
-10 10541749867008 10541749867008 average_bulk
-10 1108578125 1108578125 average_base
-8 7521800519168 7521800519168 average_bulk
-8 912786466 912786466 average_base
-6 3019949347840 3019949347840 average_bulk
-6 195791659 195791659 average_base
1248 578966159000 578966159000 type(20570500)
1248 133124071973119817 133124071973119817 type(40030500)
1250 6391050 6391050 counter
<<<winperf_if>>>
1667933597.35 510 2143274
4 instances: HP_Ethernet_1Gb_4-port_331FLR_Adapter__2 HP_Ethernet_1Gb_4-port_331FLR_Adapter__3 HP_Ethernet_1Gb_4-port_331FLR_Adapter__4 HP_Ethernet_1Gb_4-port_331FLR_Adapter
-122 21367232507 36997477487 41986280236 29526533151 bulk_count
-110 98763921 144663392 158041945 101438370 bulk_count
-244 70059131 94820354 93278071 70489646 bulk_count
-58 28704790 49843038 64763874 30948724 bulk_count
10 1000000000 1000000000 1000000000 1000000000 large_rawcount
-246 11553778380 25562438926 16966063603 12779761300 bulk_count
14 27387553 52165828 50668479 26152325 bulk_count
16 42671235 42654526 42609592 44337321 bulk_count
18 343 0 0 0 large_rawcount
20 0 0 0 0 large_rawcount
22 0 0 0 0 large_rawcount
-4 9813454127 11435038561 25020216633 16746771851 bulk_count
26 28479938 49601381 64477329 30840053 bulk_count
28 224852 241657 286545 108671 bulk_count
30 0 0 0 0 large_rawcount
32 0 0 0 0 large_rawcount
34 0 0 0 0 large_rawcount
1086 0 0 0 0 large_rawcount
1088 0 0 0 0 large_rawcount
1090 0 0 0 0 bulk_count
1092 0 0 0 0 bulk_count
1094 0 0 0 0 large_rawcount
<<<winperf_processor>>>
1667933597.36 238 2143274
33 instances: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 _Total
-232 13879880156250 13973147187500 14243953125000 14459570468750 14420197187500 14527831406250 14447382968750 14531782812500 14392465625000 14524777812500 14465054218750 14530751406250 14464741250000 14523300468750 14470248437500 14504599218750 14429865312500 14456531718750 14326863281250 14485711250000 14455559687500 14472228750000 14426120937500 14464448906250 14455892187500 14495371875000 14446571562500 14463970000000 14431289843750 14481362812500 14451175468750 14454705312500 14423667270507 100nsec_timer_inv
-96 231651093750 84686718750 155658906250 56572968750 110640156250 64656406250 90814687500 56352343750 121015468750 61479843750 95062031250 58482031250 90896093750 63090625000 85347500000 71060781250 109752187500 100644062500 92883125000 82633750000 101726875000 96081562500 111139531250 101398906250 96270000000 76519843750 104898125000 99251250000 115689843750 81571562500 102273906250 97750937500 95873535156 100nsec_timer
-94 530779218750 584470156250 242691875000 126160468750 111466562500 49816093750 104106250000 54168750000 128822812500 56046250000 82187500000 53070312500 86666406250 55912656250 86707656250 66643593750 102686093750 85127812500 222556875000 73958281250 85016718750 73992812500 105042656250 76455312500 90140781250 70411250000 90833281250 79081718750 95323281250 79368593750 88853437500 89846562500 122762875976 100nsec_timer
-90 1429056889 1222729511 631740163 939567891 255626306 147413794 260877967 136882423 240151109 136286309 215685233 143278211 216467034 152388646 308283983 166019243 135240024 119404408 1228069201 117173582 143222498 120101401 134637849 117726557 133436110 118006629 133152450 116738263 136592016 119259801 134111629 130676655 1150069193 counter
458 205081250000 286475156250 50380625000 448750000 369375000 498281250 377187500 426250000 250468750 504843750 187343750 792031250 155000000 819531250 149843750 820312500 160937500 187812500 274843750 139843750 174218750 113437500 239218750 152187500 226406250 128125000 200937500 94843750 185000000 135781250 165781250 151718750 17202104492 100nsec_timer
460 30543593750 12615781250 4901093750 5923593750 1495625000 647968750 1492031250 640937500 1505468750 612812500 782187500 998750000 845312500 1150156250 1747812500 1373437500 263125000 187187500 130021093750 171562500 432812500 232656250 249843750 217031250 243281250 191562500 238906250 185468750 347968750 202187500 259062500 428281250 6285893554 100nsec_timer
1096 1285753645 950229941 451939254 11688030 4032481 13142203 6151909 10043823 4449693 12523459 1817589 20179453 1523165 20725785 7351278 20910562 1249612 1294300 2545990 1052130 1191709 869395 1669532 1057375 1496636 921872 1323025 689758 1238273 1007776 1180578 1039073 2842289304 counter
1098 5 0 1 0 0 8 0 0 2 0 0 7 4 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 30 rawcount
1508 13806596776898 14119465141450 14188925247271 14408721303766 14359335853124 14506012491887 14408923846487 14515747433154 14352858292844 14507886505802 14416666712468 14517238049376 14427836707199 14506085266680 14427738592578 14488638121354 14400944614589 14434965269493 14259066464216 14466208894615 14424758891997 14452692972465 14397034454385 14452753966019 14428171701307 14475086534837 14417812592187 14443082531681 14395244863427 14462076387002 14422844093009 14423193590183 14397331692617 100nsec_timer
1510 416435146626 647367787389 527497953836 813767765138 1070000122826 1588228739115 2904795869762 3432460659625 3162821761603 1711674739537 58103503481 4287565055830 59774467850 5129069828304 59208489782 5622185728637 549207239135 412220273441 232887667344 568558540820 510900302275 361458704538 577487754407 413197551638 111295004791 703335174321 103459706001 746072333485 99945343670 806395308424 89580601183 971254502494 1210881675853 100nsec_timer
1512 13390161630272 13472097354061 13661427293435 13594953538628 13289335730298 12917783752772 11504127976725 11083286773529 11190036531241 12796211766265 14358563208987 10229672993546 14368062239349 9377015438376 14368530102796 8866452392717 13851737375454 14022744996052 14026178796872 13897650353795 13913858589722 14091234267927 13819546699978 14039556414381 14316876696516 13771751360516 14314352886186 13697010198196 14295299519757 13655681078578 14333263491826 13451939087689 13186450016763 100nsec_timer
1514 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100nsec_timer
1516 17642954 18502729 11341396 56669353 19176199 17001990 54657719 32599452 49859335 17892199 2830872 41160554 2985288 50532547 3391316 62228248 6745204 5701061 21941736 6056653 6695451 5288100 7085349 4685632 3049671 7101482 2733011 7697067 3009283 8600726 2558294 10546741 567967612 bulk_count
1518 1256535018 1181208817 579871767 872180930 204587778 117336738 184105075 96252256 157687180 115004429 185240106 99741651 188419973 94774575 280257567 99386273 118256121 109856788 1172339033 107281745 124652302 111298424 117125968 109364457 120211516 107487638 119641464 105223982 123216620 107122552 121324990 116110838 8603104571 bulk_count
1520 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 bulk_count
<<ps:sep(9)>>
(SYSTEM,64,4,0,0,0,0,461557304062500,0,32,1464222) System Idle Process
(SYSTEM,3392,272,0,4,0,0,627145156250,1013,349,1464222) System
(SYSTEM,4984,1100,0,952,0,0,15312500,52,2,1464222) smss.exe
(SYSTEM,51816,4232,0,216,1,695000000,10894062500,473,10,1464217) csrss.exe
(\NT AUTHORITY\SYSTEM,2147525952,4308,0,208,1,625000,7500000,85,1,1464215) wininit.exe
(SYSTEM,40908,3556,0,1028,1,312500,55625000,97,9,1464215) csrss.exe
(\NT AUTHORITY\SYSTEM,2147537820,5948,0,1072,1,468750,11875000,128,2,1464213) winlogon.exe
(SYSTEM,2147526500,13304,0,1112,14,3072031250,11858437500,263,3,1464212) services.exe
(\NT AUTHORITY\SYSTEM,2147606080,42544,0,1120,34,7242187500,10947343750,1391,8,1464212) lsass.exe
(\NT AUTHORITY\SYSTEM,2147533916,15060,0,1196,7,610468750,2354687500,510,7,1464210) svchost.exe
(\NT AUTHORITY\NETWORK SERVICE,2147535380,14736,0,1240,9,3352968750,2001562500,398,8,1464210) svchost.exe
(\NT AUTHORITY\SYSTEM,2147624056,25036,0,1328,12,2343750,10937500,327,8,1464210) LogonUI.exe
(\NT AUTHORITY\SYSTEM,878176,348016,0,1336,482,18239843750,15533125000,1450,60,1464210) CylanceSvc.exe
(\Window Manager\DWM-1,2147575316,25700,0,1356,15,8125000,9687500,181,6,1464209) dwm.exe
(\NT AUTHORITY\LOCAL SERVICE,2147560552,22772,0,1588,18,23158437500,1254062500,516,12,1464149) svchost.exe
(\NT AUTHORITY\SYSTEM,2147569116,18656,0,1620,10,425781250,1031406250,243,3,1464149) svchost.exe
(\NT AUTHORITY\SYSTEM,2147760792,73512,0,1636,54,113829687500,52228593750,1445,32,1464149) svchost.exe
(\NT AUTHORITY\LOCAL SERVICE,2147587252,15768,0,1684,9,44531250,117500000,442,17,1464148) svchost.exe
(\NT AUTHORITY\NETWORK SERVICE,2149170704,26260,0,1764,15,8304218750,6432812500,697,17,1464148) svchost.exe
(\NT AUTHORITY\LOCAL SERVICE,2147540868,14948,0,1980,12,241875000,133750000,366,16,1464148) svchost.exe
(\NT AUTHORITY\SYSTEM,2147590124,15792,0,1584,6,166093750,76562500,456,10,1464147) spoolsv.exe
(\NT AUTHORITY\SYSTEM,95884,22020,0,1748,14,7516562500,15486093750,293,19,1464147) check_mk_agent.exe
(\NT AUTHORITY\SYSTEM,764720,195556,0,2128,149,351728437500,106366093750,1229,49,1464147) CyOptics.exe
(\NT AUTHORITY\SYSTEM,2147589412,11760,0,2528,6,1562500,9687500,196,8,1464142) svchost.exe
(\NT AUTHORITY\SYSTEM,51816,9168,0,2836,2,6406250,39218750,125,10,1464133) TaniumClient.exe
(\NT AUTHORITY\SYSTEM,2147915432,13840,0,2860,14,75687812500,85226562500,201,37,1464133) TaniumDriverSvc.exe
(\NT AUTHORITY\SYSTEM,2147558556,3500,0,2884,0,625000,9531250,75,3,1464133) TaniumDriverSvc.exe
(\NT AUTHORITY\SYSTEM,2149151040,16696,0,3036,17,295000000,69062500,379,10,1464133) svchost.exe
(\NT AUTHORITY\SYSTEM,67952,6004,0,3064,2,11093750,17968750,165,12,1464133) tvnserver.exe
(\NT AUTHORITY\SYSTEM,2147645976,43396,0,196,25,19793281250,4377031250,764,13,1464132) vmms.exe
(\NT AUTHORITY\NETWORK SERVICE,2147705456,21792,0,3312,18,486875000,470156250,743,118,1464132) svchost.exe
(\NT AUTHORITY\NETWORK SERVICE,2147506588,4648,0,3376,1,2187500,12031250,112,3,1464132) svchost.exe
(\NT AUTHORITY\SYSTEM,2147600220,39280,0,3748,30,12617500000,79971718750,282,9,1464131) WmiPrvSE.exe
(\NT VIRTUAL MACHINE\AD704315-7C35-40D9-B4A6-8B720E01A0DD,2147633180,23992,0,5008,12,3686406250,1941718750,566,33,1464119) vmwp.exe
(\NT VIRTUAL MACHINE\5036765F-8664-4FE3-BECC-745348B7901D,2147627344,22416,0,5140,11,4451406250,30500312500,531,26,1464116) vmwp.exe
(\NT VIRTUAL MACHINE\0F291EC5-5B93-4A57-95F9-DB7B60943CAF,2147643792,30808,0,5260,19,3996406250,22104843750,582,28,1464115) vmwp.exe
(\NT VIRTUAL MACHINE\74F265DE-477C-4970-AB02-AD5980F7EA6F,2147625904,20972,0,5404,41,4323281250,28203281250,523,26,1464114) vmwp.exe
(\NT AUTHORITY\NETWORK SERVICE,2147528312,7228,0,2080,2,1875000,11875000,166,9,1464009) msdtc.exe
(\NT AUTHORITY\NETWORK SERVICE,2147582720,33840,0,6320,24,15574218750,98744843750,499,9,530726) WmiPrvSE.exe
(\NT AUTHORITY\SYSTEM,69876,10256,0,1508,2,2031250,1562500,129,7,7930) TaniumClient.exe
(\NT AUTHORITY\SYSTEM,2147516296,3588,0,3980,0,781250,2812500,66,2,7930) conhost.exe
(\NT AUTHORITY\SYSTEM,150116,23644,0,8132,14,141250000,253906250,537,62,7930) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,119316,34292,0,7280,21,17187500,13125000,247,7,7929) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,80204,13688,0,4992,3,3125000,3593750,222,8,7927) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,126480,33208,0,960,19,127031250,50000000,377,13,7926) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,87156,15196,0,4472,4,5781250,4375000,251,10,7925) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,85048,16420,0,2580,3,4062500,3437500,205,8,7925) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,81528,14528,0,7808,4,4218750,4062500,178,8,7924) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,85472,16632,0,5612,4,3125000,4062500,221,8,7923) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,71028,15188,0,4160,4,11718750,6406250,351,12,7923) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,120208,29688,0,6672,16,22031250,10937500,460,16,7922) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,99780,19044,0,6228,5,96406250,190156250,372,11,7921) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,929044,39824,0,5856,34,141406250,54531250,300,42,7920) TaniumCX.exe
(\NT AUTHORITY\SYSTEM,52120,4244,0,6636,2,468750,1406250,53,1,7918) cmd.exe
(\NT AUTHORITY\SYSTEM,128580,19296,0,2124,11,2310312500,547812500,218,5,7918) cscript.exe
(\NT AUTHORITY\SYSTEM,130996,58036,0,2332,44,1098750000,659062500,322,1,7918) TPython.exe
(\NT AUTHORITY\SYSTEM,109688,41204,0,7604,31,238906250,122187500,519,26,4314) TaniumClient.exe
(\NT AUTHORITY\SYSTEM,2147516296,3588,0,2756,0,781250,5781250,51,2,4314) conhost.exe
(\NT AUTHORITY\LOCAL SERVICE,2147533212,11108,0,7904,5,2031250,9687500,227,7,76) WmiPrvSE.exe
(\NT AUTHORITY\NETWORK SERVICE,73812,8092,0,8704,3,937500,2187500,154,7,55) WmiPrvSE.exe
(\NT AUTHORITY\SYSTEM,87016,19612,0,7508,6,2187500,3593750,183,5,14) TaniumClient.exe
(\NT AUTHORITY\LOCAL SERVICE,68384,7332,0,7836,2,625000,2500000,152,6,11) WmiPrvSE.exe
1667933597
Hey Andreas,
just bumped into this thread - does your modified (extended) hyperv-plugin still exist?
Best
Nora
