Hi
we just wish to monitor open files of linux system in check_mk.
what are the steps i need to follow ?
can somebody guide ?
Hi
in the linux agent file downloads you can find the file mk_filehandle.
This monitors the file /proc/sys/fs/file-nr
The three values in file-nr denote the number of allocated file handles, the number of allocated but unused file handles, and the maximum number of file handles.
If you copy that file to the monitored host in the folder /usr/lib/check_mk_agent/plugins and make it executable, it should extend the agent with that data.
Exactly, and the service will look like this. Unfortunately the big number is not formatted very nicely.
There is an MKP for the bakery: Checkmk Exchange
Unfortunately this is not a solution if you want to monitor the file handles per user. In that case, you will probably have to write your own script and run it as a local check.
Kind regards,
