How to Monitoring data transfer?
Hello Guys!
I checked that the hostname in Check-MK was incorrectly registered
I want to move the monitoring data on the incorrectly registered server to the registered server again.
I try to use the hostname change function, but check-mk is interrupted because there are too many
Is it possible to transfer the monitoring data in a way other than the host name change function?
