Hi I fount this “Locked by” in the Host Properties, I would love to at least prevent some Hosts from Deleting.
I fount some configuration for the hole wato file or folder, but a single host would be nice.
You seem to be misunderstanding these
fields.
They get filled by checkmk if you engage the dynamic configuration daemon and configure it to add and remove hosts automatically, based on piggyback data. If the DCD adds a host, then some of the host attributes are set by this process and cannot be changed. They are locked:
