I created a gist (Github Code Snippets) for an example fail2ban jail to protect your CheckMK web UI login form against brute-force attacks by banning the attackers IP address for a while after too many failed login attempts.
You can also always find the latest version here: Fail2ban Config for CheckMk Authentication over Web UI · GitHub
CheckMk Web Auth Fail2ban Config
This is a example fail2ban config for failed login attempts in the CheckMK Web UI Login Form.
Setup
Check for log files
CheckMK logs failed login attempts for each site separately at ~/var/log/web.log
(relative path from the site’s user).
To view them, type sudo ls -l /omd/sites/*/var/log/web.log
Or as a checkmk user: First change to the user of your checkmk site with omd su <sitename>
, then type ls ~/var/log/web.log
Create Fail2Ban Filter and Jail
- If not already done, install fail2ban (e.g. for Ubuntu:
apt install fail2ban
) - Create 2 new files with the following path and name and copy the content inside the code block (Click on them to see the code).
/etc/fail2ban/filter.d/checkmk-auth.conf
# checkmk-auth configuration file
[Definition]
# Option: failregex
# Notes.: regex to match the password failures messages in the logfile. The
# host must be matched by a group named "host". The tag "<HOST>" can
# be used for standard IP/hostname matching and is only an alias for
# (?:::f{4,6}:)?(?P<host>\S+)
# Values: TEXT
failregex = Login failed for username: <F-USER>.*</F-USER> \(existing: .*, locked: .*, failed logins until locked: .*\), client: <HOST>$
# Option: ignoreregex
# Notes.: regex to ignore. If this regex matches, the line is ignored.
# Values: TEXT
ignoreregex =
datepattern = ^%%Y-%%m-%%d %%H:%%M:%%S,%%f\s
/etc/fail2ban/jail.d/checkmk-auth.conf
[checkmk-auth]
enabled = true
filter = checkmk-auth
# See the docs for information about used ports: https://docs.checkmk.com/latest/en/ports.html#loopback
# Specify a single port (port=5000) and multiple ports comma-separated (e.g. port=5000,5001,5002) or as a range (e.g. port=5000:5010)
port=5000:5100
action = iptables-multiport[name=checkmk-auth, protocol=tcp]
logpath = /omd/sites/*/var/log/web.log
maxretry = 5
- If needed, change the port or add additional ports at line 8 in
for your checkmk sites (each site has its own port. See the docs for more information about used ports: Ports - Ports used by Checkmk) - To test your fail2ban config, run
fail2ban-regex /omd/sites/*/var/log/web.log /etc/fail2ban/filter.d/checkmk-auth.conf
- Reload fail2ban to activate the config:
fail2ban-client reload --restart checkmk-auth
orsystemctl reload fail2ban.service
- Check if fail2ban knows about the new jail:
fail2ban-client status checkmk-auth
Testing
- Make some login attempts that will fail (wrong username or password)
- To test the filter, run
- To test the jail, run
Statistics
To see statistics about the checkmk-auth jail, run fail2ban-client status checkmk-auth
