Hello Everyone,
I need your advise on this.
I have two independent monitoring setups ( 1 master -> 2 slaves) both 1.5.0p15 . One setup is called DEV and the other is PROD. There are some config files which are same between both the setups. These files are namely the following:
contacts.mk
users.mk
roles.mk
hosttags.mk
groups.mk
$OMD_ROOT/local/share/check_mk/checks/
Now, lets say, if I add a contact group and then assign a role and a contact group to a user on DEV, then I have to go to PROD and do the same stuff. Is there a way I can pro-grammatically sync the configs or what do you suggest ?
I was thinking of using WATO Git version control global setting and then use use $OMD_ROOT/etc/check_mk and storing it remotely in a repo on GitLab/Github with two branches lke dev and prod. I have no idea how to sync “$OMD_ROOT/local/share/check_mk/checks/”.With the DEV branch, I will pull the changes on DEV instance master and if all is good then will create a merge request to PROD branch and then all pull the changes on PROD master instance. This is just an idea. I have no experience on implementing it.
Have you also faced this problem and how did you solved it ?
