How turn on display help texts / inline help on v2.3
Hey. I am looking for how can I enable help text in Web interface version 2.3.
You mean this one?
grafik
or the Help section?
grafik
Thanks. First image is good. I found it there.
Can you please mark the answer as the solution if it solved your problem?
Sara Sorry. I forgot , but I do it right now.
