Hi all
How is computed the temperature of zone 0 / zone 1 in Gen 10 HPE servers plugin output ?
HPE servers has 35 sensors that can go from around 25 degress centigrade in the Inlet area to 100 degrees centigrade in PCI slots area.
There’s an average ? Which value is kept in the plugin output ?
We’re using 2.0.0p12 CEE. Agent is also 2.0.0p12.
Agent output:
thermal_zone0|enabled|x86_pkg_temp|58000|0|passive|0|passive
thermal_zone1|enabled|x86_pkg_temp|55000|0|passive|0|passive
What you see in your temperature output of the “thermal zone” is not computed anywhere.
This is read directly from “/sys/class/thermal/thermal_zone…”
From where your Linux system gets the values i don’t know.
If you have a hardware server with proper management interface i would recommend to use this to get the real values for your temperature sensors.
Most times the Linux thermal is not usable.
