@fjacuqet Does the “FQDN” you specify in the check_http call resolve as the same IPv4-address that is configured for the host you are running the active check for? The way i see it, you are running the check_http against a FQDN and the active check receives a IPv4-address as a host-parameter.
Finally found it, using CLI is not 100% like active mode. I finally fixed it by declaring the hostname as a virtual host. This way active mode is happy, and I can do my monitoring.
checkmk always return to IP even if I never use them so we must declare virtual hosts as they are
