Huawei Storage Plugin 2.3 not working in Checkmk Enterprise Edition 2.1.0p18
i’ve updated my site from cme 1.6 to 2.1 and it seems that the huawei storage plugin 2.3 from Robert didn’t work anymore. I get the following error messages:
Some GUI extensions could not be loaded. This may be caused by some incompatible extension packages.
Loading “/omd/sites/XXXXXXX/local/share/check_mk/web/plugins/metrics/huawei.py” failed: name ‘df_translation’ is not defined
Has anyone this plugin or a new one running on cme 2.1.x ?
Regards
Raphael
huawei-3.1.1.mkp (28.5 KB)
I patched into it a little bit, but only had one device at a customer, so I’m not sure if this will fit all devices. But this should work in 2.1
thanks to @r.sander for the initial mkp :slight_smile:
We found that the Huawei SNMP agent is not efficient enough to use it.
The folks from comnet in Hannover implemented a special agent based on the Huawei HTTP API which works better. You have to ask them (https://comnetgmbh.com/) if you want to use it.
Is it possible to use this special agent for dorado devices as well?
Regards
Christian
I do not know. Please ask the comnet team.
Thx, for the new version. This worked for me. I remember to talk to some guys from comnet on the cmk conference. Perhaps i will find the contactdata and ask them for the special agent.
did you know if this agent supports dorado and oceanstor devices?
Regards
Raphael
