I am trying to monitor a Hyper-v but I have some problems with the information, I see these plugins available to monitor a Hyperv:
But in my cmk distribution I only see these plugins:
hyperv_vms.ps1
and
Hyper-V VM state
Apparently hyperv_vms.ps1 only shows this information:
and the Hyper-V VM status show this:
more…
Can anyone explain the function of these plugins and the installation process to me?
Mi CMK version is 1.6.0p15 RAW
Thank you!
You refer to some external check plugins something like my version here.
Do you have installed some mkp package?
Or better said from where are these plugins?
if you check the description of these checks you need (hyperv_vms_guestinfos.ps1
) as welk.
BR
Anastasios
Hi @andreas-doehler .
In the app - WATO - Monitoring Agents you can find these plugins:
and yes @athomaidis I see the information you mentioned, but the name of the plugin is different
@Gustavo in 1.6 Hyper-V VM state should be hyperv_vms_guestinfos.ps1.
In Checkmk 2.0 we correct the names:
system
(system)
Closed
June 10, 2022, 6:56am
6
