Hyper-V State of VM's - Two replica servers with vm's split running
Hi all,
We have 2 Hyper-V Servers running, which replicate on to each other and each VM runs on one server while only being replicated to the other. Where they run is split up as a kind of “manual load balancing”. We can’t use a proper cluster for certain reasons.
Now to the problem: Is the only way to not get “VM State is off” Alarms on the server a VM is NOT running on to use the rule to set State: off to “OK” on the server it isn’t running on?
Is there some way to make cmk recognize that the state on both servers is “OK” if a VM is running on one of the two servers? I tried looking around for plugins, but the few things I did find were severely outdated.
