CMK version: 2.1.0p26
OS version: CentOS Linux release 7.9.2009 (Core)
Error message: Invalid check parameter : The data type of the value does not match any of the allowed alternatives.
Variable: checkgroup_parameters:hyperv_vms
OMD[noc]:~$ cmk --debug -vvn xxx.xxx.xxx
Checkmk version 2.1.0p26
Trying to acquire lock on /omd/sites/noc/var/check_mk/license_usage/next_run
Got lock on /omd/sites/noc/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/noc/var/check_mk/license_usage/history.json
Got lock on /omd/sites/noc/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/noc/var/check_mk/license_usage/history.json
Released lock on /omd/sites/noc/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/noc/var/check_mk/license_usage/next_run
Released lock on /omd/sites/noc/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f6eaece32b0]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(xxx.xxx.xxx, base_path=/omd/sites/noc/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 39 sec, allowed is 0 sec)
Connecting via TCP to xxx.xxx.xxx:6556 (5.0s timeout)
Detected transport protocol: TransportProtocol.TLS (b'16')
Write data to cache file /omd/sites/noc/tmp/check_mk/cache/xxx.xxx.xxx
Trying to acquire lock on /omd/sites/noc/tmp/check_mk/cache/xxx.xxx.xxx
Got lock on /omd/sites/noc/tmp/check_mk/cache/xxx.xxx.xxx
Releasing lock on /omd/sites/noc/tmp/check_mk/cache/xxx.xxx.xxx
Released lock on /omd/sites/noc/tmp/check_mk/cache/xxx.xxx.xxx
Closing TCP connection to xxx.xxx.xxx:6556
[cpu_tracking] Stop [7f6eaece32b0 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.0, children_user=0.0, children_system=0.0, elapsed=6.3900000005960464))]
[cpu_tracking] Start [7f6eaec693d0]
[PiggybackFetcher] Fetch with cache settings: NoCache(xxx.xxx.xxx, base_path=/omd/sites/noc/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'xxx.xxx.xxx'. Skip processing.
[cpu_tracking] Stop [7f6eaec693d0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<wmi_cpuload:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<fileinfo:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_phydisk>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_if>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_processor>>> / Transition HostSectionParser -> HostSectionParser
<<<df:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<logwatch>>> / Transition HostSectionParser -> HostSectionParser
<<<checkmk_agent_plugins_win:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<services>>> / Transition HostSectionParser -> HostSectionParser
<<<ps:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<dotnet_clrmemory:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<wmi_webservices:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
Transition HostSectionParser -> NOOPParser
<<<hyperv_vms:sep(9)>>> / Transition NOOPParser -> HostSectionParser
PiggybackMarker(hostname='xxxxx_') / Transition HostSectionParser -> PiggybackParser
PiggybackMarker(hostname='xxxxx_') SectionMarker(name=SectionName('hyperv_vmstatus'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator=None) / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='xxxxx_') SectionMarker(name=SectionName('hyperv_checkpoints'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator=None) / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='xxx.xxx.local') / Transition PiggybackSectionParser -> PiggybackParser
PiggybackMarker(hostname='xxx.xxx.local') SectionMarker(name=SectionName('hyperv_vmstatus'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator=None) / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='xxx.xxx.local') SectionMarker(name=SectionName('hyperv_checkpoints'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator=None) / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='xxx') / Transition PiggybackSectionParser -> PiggybackParser
PiggybackMarker(hostname='xxx') SectionMarker(name=SectionName('hyperv_vmstatus'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator=None) / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='xxx') SectionMarker(name=SectionName('hyperv_checkpoints'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator=None) / Transition PiggybackSectionParser -> PiggybackSectionParser
PiggybackMarker(hostname='xxx_') / Transition PiggybackSectionParser -> PiggybackParser
PiggybackMarker(hostname='xxx_') SectionMarker(name=SectionName('hyperv_vmstatus'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator=None) / Transition PiggybackParser -> PiggybackSectionParser
PiggybackMarker(hostname='xxx_') SectionMarker(name=SectionName('hyperv_checkpoints'), cached=None, encoding='utf-8', nostrip=False, persist=None, separator=None) / Transition PiggybackSectionParser -> PiggybackSectionParser
Transition PiggybackSectionParser -> NOOPParser
Transition NOOPParser -> NOOPParser
<<<systemtime>>> / Transition NOOPParser -> HostSectionParser
No persisted sections
-> Add sections: ['check_mk', 'checkmk_agent_plugins_win', 'cmk_agent_ctl_status', 'df', 'dotnet_clrmemory', 'fileinfo', 'hyperv_vms', 'logwatch', 'mem', 'ps', 'services', 'systemtime', 'uptime', 'winperf_if', 'winperf_phydisk', 'winperf_processor', 'wmi_cpuload', 'wmi_webservices']
-> Add sections: []
Storing piggyback data for: 'xxx_'
Trying to acquire lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx_/xxx.xxx.mnet
Got lock on /omd/sites/noc/tmp/check_mk/piggyback/builder.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.mnet
Releasing lock on /omd/sites/noc/tmp/check_mk/piggyback/builder.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.mnet
Released lock on /omd/sites/noc/tmp/check_mk/piggyback/builder.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.mnet
Storing piggyback data for: 'xxx.xxx'
Trying to acquire lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local/xxx.xxx
Got lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local/xxx.xxx
Releasing lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local/xxx.xxx
Released lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local/xxx.xxx
Storing piggyback data for: 'xxx.xxx.xxx'
Trying to acquire lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.xxx/xxx.xxx.xxx
Got lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.xxx/xxx.xxx.xxx
Releasing lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.xxx/xxx.xxx.xxx
Released lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.xxx/xxx.xxx.xxx
Storing piggyback data for: 'xxx.xxx.local__ex_xxx.xxx.xxx_'
Trying to acquire lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.xxx
Got lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.xxx
Releasing lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.xxx
Released lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.xxx
Received piggyback data for 5 hosts
Storing piggyback data for: 'builder.xxx.local__ex_xxx.xxx.xxx_'
Trying to acquire lock on /omd/sites/noc/tmp/check_mk/piggyback/builder.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.xxx
Got lock on /omd/sites/noc/tmp/check_mk/piggyback/builder.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.xxx
Releasing lock on /omd/sites/noc/tmp/check_mk/piggyback/builder.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.xxx
Released lock on /omd/sites/noc/tmp/check_mk/piggyback/builder.xxx.local__ex_xxx.xxx.xxx_/xxx.xxx.xxx
Storing piggyback data for: 'xxx.xxx.local'
Trying to acquire lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local/xxx.xxx.xxx
Got lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local/xxx.xxx.xxx
Releasing lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local/xxx.xxx.xxx
Released lock on /omd/sites/noc/tmp/check_mk/piggyback/xxx.xxx.local/xxx.xxx.xxx
[cpu_tracking] Start [7f6eaec0ff40]
value store: synchronizing
Trying to acquire lock on /omd/sites/noc/tmp/check_mk/counters/xxx.xxx.xxx
Got lock on /omd/sites/noc/tmp/check_mk/counters/xxx.xxx.xxx
Releasing lock on /omd/sites/noc/tmp/check_mk/counters/xxx.xxx.xxx
Released lock on /omd/sites/noc/tmp/check_mk/counters/xxx.xxx.xxx
CPU utilization Total CPU: 2.62%
Check_MK Agent Version: 2.1.0p26, OS: windows, Agent plugins: 2, Local checks: 0
Disk IO SUMMARY Read: 112 kB/s, Write: 502 kB/s, Latency: 13 milliseconds
DotNet Memory Management _Global_ Time in GC: 0.02%
Interface Broadcom BCM5716C NetXtreme II GigE [NDIS VBD Client] 39 [4], (Connected), Speed: 1 GBit/s, In: 331 B/s (<0.01%), Out: 514 B/s (<0.01%)
Interface Broadcom BCM5716C NetXtreme II GigE [NDIS VBD Client] 40 [3], (Connected), Speed: 1 GBit/s, In: 212 B/s (<0.01%), Out: 272 B/s (<0.01%)
Interface Intel[R] 82576 Gigabit Dual Port Network Connection [1], (Connected), Speed: 1 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
Interface Intel[R] 82576 Gigabit Dual Port Network Connection 2 [2], (Connected), Speed: 1 GBit/s, In: 331 B/s (<0.01%), Out: 369 B/s (<0.01%)
Interface isatap.{4FAA39FD-D847-4A28-8B95-C2A9610DED32} [5], (Connected), Speed: 100 kBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
LOG Application No error messages
LOG HardwareEvents No error messages
LOG Internet Explorer No error messages
LOG Key Management Service No error messages
LOG Security No error messages
LOG System No error messages
LOG Windows PowerShell No error messages
Memory and pagefile RAM: 75.8% - 18.19 GB of 23.99 GB, Commit charge: 67.97% - 18.69 GB of 27.49 GB
Processor Queue 15 min load: 0.01, 15 min load per core: 0.00 (8 logical cores)
Service Summary Autostart services: 53, Stopped services: 3
System Time Offset: -9.53 s
Uptime Up since Dec 15 2022 16:11:27, Uptime: 129 days 18 hours
VM xxx.xxx.xxx State is Running (Operating normally)
Web Service Default Web Site Connections: 0.00
fs_C:/ 29.77% used (40.42 of 135.78 GB), trend: +117.39 MB / 24 hours
fs_D:/ 10.19% used (284.80 GB of 2.73 TB), trend: -12.49 GB / 24 hours
No piggyback files for 'xx.xx.xxx'. Skip processing.
[cpu_tracking] Stop [7f6eaec0ff40 - Snapshot(process=posix.times_result(user=0.020000000000000018, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.020000001415610313))]
[agent] Success, execution time 6.4 sec | execution_time=6.410 user_time=0.030 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=6.380
