Hello All,
I’m using Check_MK Raw 2.1 0p9 and I need to monitor IBM Flash System devices. I’ve configured them via SNMP, but Check_MK isn’t detecting them and is throwing a timeout error. The storage team assures me that I’ve already configured the SNMPv3 community on the devices.
I’ve configured a rule called IBM SVC/V7000 storage systems, but it’s not working.
The devices are: IBM Flashsystem 7200
I ran the following command: ssh-keygen -t rsa -b 4096 -f ~/.ssh/id_ibmflash -N "" to create a key on the Check_MK server with the OMD user, but the rule I mentioned doesn’t ask for the key, only a user.
Is there any special configuration for these types of devices?
SMPv3 error:
SNMP Error on 0.0.0.0: snmpbulkwalk: Timeout (Exit-Code: 1)
Thanks in advance.
Regards,
Vix
